The Buzzard Posted January 13, 2009 Share Posted January 13, 2009 Hello again to all, I have attached a lisp program that some may find useful. It is my concept of a Dimension Style Manager. I started to put this program together about a year ago, And have continued to work on it since. It works well considering it does not have every feature you would find in AutoCAD's manager, But it was setup to suit my needs so that I could get dimstyles on the fly. The program is well annotated so that you may understand how it works. What make it so good is the idea to program your own defaults into it, So all you would really need to do is select a Dimension Unit & click OK. I put the other settings in for the sole purpose of having some flexiblity for those times when you need to change something for a special project. Give it a try. Instructions are included in the program header with a function map. Enjoy! The Buzzard DSM.zip 1 Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted January 13, 2009 Author Share Posted January 13, 2009 My apologies, I accidently grabed an additional file that was not part of the attached zip file. This file has now been replaced. I also want to mention that this program is set to do both Metric and Imperial dimensions styles. Again Sorry, The Buzzard Quote Link to comment Share on other sites More sharing options...
ebrito Posted January 19, 2009 Share Posted January 19, 2009 There is no file attached Quote Link to comment Share on other sites More sharing options...
The Buzzard Posted January 19, 2009 Author Share Posted January 19, 2009 Please see the DSM.zip on the first post and download, the files are in the zip. Quote Link to comment Share on other sites More sharing options...
