Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Forum Newbie
    andi blinco's Computer Details
    Windows XP
    AutoCAD 2007
    Jan 2009
    Newbury
    8
    Default How to change scale in Autocad07
    Hi All,
    Need help please using Autocad 2007.
    If I have drawing that was drawn in scale 1:1250 in model space but I want to show this in paper space as scale 1:500 the dwg will obviously be tiny.
    How do I change the scale in model space so that it can be presented in paper space fitting the page at scale 1:500 on size A1?
    Is there a calculation I need to change the model space dwg? If so can anyone help?
    Thankyou all
    Senior Member bonehead411's Avatar
    bonehead411's Computer Details
    Windows 10
    Dell Optiplex 9020
    8.00 GB
    Dell
    Mechanical
    bonehead411's Discipline Details
    Mechanical Engineer, Chemical Engineering
    Mechanical
    AutoCAD LT 2016
    Jan 2007
    Rawcliffe Bridge, Goole, East Yorkshire, England
    219
    Firstly, welcome to CADTutor andi.
    Select everything in modelspace and use the SCALE command to scale everything back up to 1:1 (a scale factor of 1250 in this case)
    This is how all objects should be drawn in modelspace, at 1:1. Don't let anyone tell you any different ;-)
    Now you can create a viewport in your layout and set the scale to 1:500.
    Forum Newbie
    Windows XP
    AutoCAD 2007
    Jan 2009
    Newbury
    8
    Hi,
    I've now done this so dwg is at 1:1 scale.
    When I create Viewport and set to 1:500 scale the dwg is really small, so I'm thinking something is not right with my model space dwg.
    I may be wrong but even though the dwg is now set to 1:1 scale it was originally drawn to scale 1:1250 and I had this copied over to cad (its a bit messy), does this make a difference.
    Thanks again
    Super Member skipsophrenic's Avatar
    skipsophrenic's Computer Details
    Vista 32 bit
    Compaq
    erm . . yeah?
    Intel Pentium Dual CPU E2140 @ 1.60 Ghz
    2039MB
    don't ask you'll kill me
    360gb
    21" widescren - 16:10 ratio
    AutoCAD 2008
    Jul 2008
    Birmingham, United Kingdom
    1,020
    Was it originally a pdf?
    Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. - Albert Einstein
    SET FILEDIA = 1
  5. #5
    Forum Newbie
    Windows XP
    AutoCAD 2007
    Jan 2009
    Newbury
    8
    Hi,
    Sort of I copied this drg over from a in house application so I suppose it more or less is sort of a pdf file but you can completeley edit and change the dwg in cad.
    Thanks
    Andi
  6. #6
    Forum Newbie
    Windows XP
    AutoCAD 2007
    Jan 2009
    Newbury
    8
    I should of mentioned this file is a dxf file which was already drawn to scale 1:1250.
    All i'm trying to do is show this in view port as scale 1:500 without the dwg being tiny on the vp? Do I need to enlarge the 1:1250 dwg I have so that my vp will fit 1:500 scale?
    Thanks again
  7. #7
    Vista 32 bit
    Compaq
    erm . . yeah?
    2039MB
    360gb
    AutoCAD 2008
    Jul 2008
    1,020
    yeah, (Save a backup incase this doesn't work)
    Type in SCALE then select everything you need to enlarge, press enter, select a base point (0,0 best) then type in 1250.
    Then go to your layout tab and set viewport to 1:500
    Other method
    Type in SCALE then select everything you need to enlarge, press enter, select a base point (0,0 best) then type in RE and press enter, then type in 1 and press enter, then put in 1250
    SET FILEDIA = 1
  8. #8
    Forum Newbie
    Windows XP
    AutoCAD 2007
    Jan 2009
    Newbury
    8
    Thanks for prompt reply its much appreciated, I'll give this a go.
    Andi
  9. #9
    Junior Member CruizerCAD's Avatar
    CruizerCAD's Computer Details
    xp pro
    22" Acer
    AutoCAD 2009
    Jan 2009
    Birmingham Alabama
    16
    I had a student once that had something similar happen. When I checked the square footage on his house it was 22,500 sq.ft. instead of 2250....lol. Ole scale command bit him.
  10. #10
    Windows 10
    Dell Optiplex 9020
    8.00 GB
    Dell
    Mechanical
    Mechanical
    AutoCAD LT 2016
    Jan 2007
    219
    Just a thought Andi, have you checked the original drawing actually is 1:1250?
  1. How to I change the scale in only one axis?
    By jps in forum AutoCAD General
    Last Post: 29th May 2007, 10:59 am
  2. Change PDF scale?
    By Starkey in forum AutoCAD General
    Last Post: 8th Mar 2007, 10:30 pm
  3. y change insertion scale
    By al_farooq in forum AutoCAD Beginners' Area
    Last Post: 4th Mar 2007, 11:08 pm
  4. Change the default line scale
    By twistie in forum AutoCAD General
    Last Post: 11th Jun 2006, 03:11 am
  5. How do I change the drawing scale?
    By Ste1978 in forum AutoCAD Drawing Management & Output
    Last Post: 17th May 2006, 10:08 pm
