Results 1 to 10 of 10
Thread: Arrow fill
    Senior Member
    cadmando2's Computer Details
    Windows 7
    AutoCAD 2014
    Aug 2007
    149
    Default Arrow fill
    I was working away and just before I was getting readly to print when I found that my arrows where not filled.
    I check the arrowheads and it is set to "closed filled.
    and the text is ok.
    I have had this happen before but the text was the same way. how can I fix this?
    Senior Member brawleyman's Avatar
    brawleyman's Computer Details
    Windows 7
    Dell Precision T3500
    Intel Xeon W3530 (4x2.8Ghz)
    12Gb DDR3
    Nvidia Quadro 600
    250Gb
    2x Dell Ultrasharp 24" 1920x1080
    AutoCAD 2013
    Oct 2008
    Bentonville, AR
    103
    When you invoke your quick leader command, push "S" for settings and see what your leader arrow is set to. Sometimes, when I open a drawing that someone else has worked on, it is changed manually instead of changing it in the dimension style. Seems that they are being overridden by something like that. Hope it helps.
    Guess what? I got a fever! And the only prescription.. is more Cad Lines!
    Senior Member
    Windows 7
    AutoCAD 2014
    Aug 2007
    149
    I'm using AutoCAD 2008 and have not used the leader command all day. I check my setting and there fine. I even to the time to compare with another drawing and setvar's and couldn't find any thing. I mit of over looked something. working on a dead line and have not had time to realy at the time to look.
    just thought someone has had the same thing happen to them.
    But it is happen to solid arrow?
    So it couldn't be a leader line setting. see drawing
    Senior Member
    Windows 7
    AutoCAD 2014
    Aug 2007
    149
    The was the veriable fillmode!
  5. #5
    Forum Newbie
    Civil 3D 2009
    Feb 2009
    3
    Quote Originally Posted by cadmando2 View Post
    I'm having a similar problem, except the whole arrow doesn't show up.
    This happens with dimensions. The leader arrows are fine, but dimension arrows that are "closed fill" do not show up. When I switch to a "open fill" arrow type, it shows up fine. The arrow size is not the problem.
    Any sugguestions?
  6. #6
    Full Member GliderRider's Avatar
    AutoCAD 2009
    Nov 2008
    Canada
    29
    I'm having the same problem. Arrows are set to closed fill, but don't show up. Don't show up in the preview of the dims either. Other styles work ok, but I need closed fill.
  7. #7
    Super Member
    wannabe's Computer Details
    XP
    AutoCAD 2007
    Oct 2008
    Birmingham, UK
    772
    Dim arrows need a dimension length to be a minimum value before they show. Not saying it applies here, probably not considering other termination symbols appear fine. But what happens if you place a leader with a huge distance between the first two points?
    Long shot...
  8. #8
    Forum Newbie
    AutoCAD 2008
    Jan 2014
    1
    try tools>options>display tab>display performance> check Apply Solid Fill
  9. #9
    Forum Newbie
    AutoCAD 2010
    Jun 2014
    1
    i guess you are in hidden view style...
    if its true,as my exprience its imposibble to plot a closed fill arrow head in a hidden viewstyle...try to use another style and the closed arrow will appear....
  10. #10
    Junior Member
    AutoCAD 2015
    Dec 2008
    15
    If your FILLMODE is set to "0", it must be set to "1"...
  1. Cut and Fill w/ assemblies
    By Vanslayer1 in forum Civil 3D & LDD
    Last Post: 18th Aug 2008, 03:56 am
  2. Dim Tick Fill?
    By asptamer in forum AutoCAD Drawing Management & Output
    Last Post: 18th Jun 2007, 02:07 pm
  3. how do I fill an area?
    By The Autocad Virgin in forum AutoCAD Beginners' Area
    Last Post: 14th Jan 2006, 04:31 pm
  4. Text Fill
    By FREEFORM in forum AutoCAD Beginners' Area
    Last Post: 7th Jun 2005, 03:08 pm
