Dimensions
Johnart2000
I did the exercise on this website entitled "Masterplan".(in the totorial section).when it came time to do the dimensioning , though the dimension lines appeared they did not have any values. Would the dimensions be placed their prior to printing? How can I view the drawing ahead of time and see the dimensions.?
Sounds like a problem with the dimscale. Zoom in very close to the center or end of a dimension, you'll probably find your text and arrows, right?
Usually the case, dimension appears as a dot until you zoom in close. Ahhhhhhhhhh! 8)
