Results 1 to 7 of 7
    Senior Member bbankston's Avatar
    bbankston's Computer Details
    Windows XP
    Dell Intel(R) Pentium(R) Dual CPU E2140 @ 1.60GHz 1.59 GHz
    1.95 GB of RAM
    80 GB
    DELL
    AutoCAD LT 2008
    Apr 2008
    Houston, TX
    421
    Question I'd like to import a hatch
    How do I go about doing this? I found a wood hatch pattern on http://www.cadcorner.ca/hatch.php but I don't know how to import it into CAD. Any and all help is greatly appreciated!
    You should have seen me before the plastic surgery!
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,543
    R.K. McSwain
    CAD Panacea | twitter
    Windows XP
    1.95 GB of RAM
    80 GB
    DELL
    AutoCAD LT 2008
    Apr 2008
    Houston, TX
    421
    I don't understand.
    Custom Hatch patterns/ PAT-extension file rules:
    1. File name and hatch pattern name must be one and the same.
    2. One hatch pattern per file.
    3. there must be a single blank line at the end of the definition in the PAT
    file.
    4. The PAT file(s) must be in AutoCAD's search path.
    How do I put it in AutoCAD's search path?
    Senior Member A1DWG's Avatar
    A1DWG's Computer Details
    Win XP
    AutoCAD LT 2008
    Nov 2008
    England
    130
    Hi,
    hopefully the hatchpattern you have downloaded will have the points 1 to 4 already covered.
    You need to copy this file to your support path location, as versions of AutoCAD vary in there location paths, its often easier to use windows to search your hard drive for *.pat and copy your file there.
    I would guess as c:docs and settings/username/application data/autodesk/ and look there for the "Support Folder". Put the file there and it should work.
  5. #5
    Windows XP
    1.95 GB of RAM
    80 GB
    DELL
    AutoCAD LT 2008
    Apr 2008
    Houston, TX
    421
    Thank you very much, A1DWG. That worked perfectly! And jeez! AutoCAD doesn't make this easy do they? Heck, Adobe software is MUCH easier than that!
  6. #6
    Win XP
    AutoCAD LT 2008
    Nov 2008
    England
    130
    Quote Originally Posted by bbankston View Post
    Glad to be of help. There are lots of AutoCAD quirks, but all in all its not a bad package.
  7. #7
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,543
    For long term enjoyment... Create your own directory and put all your custom stuff in there like hatch patterns, "acad.lsp" and "acaddoc.lsp", linetype files, shape files, menu files, etc.
    Put this new directory at the TOP of your support file search path.
    Then when you upgrade, reinstall, etc. - all you have to do is add this one support path to AutoCAD. No more searching the hard drive for all your custom files, etc.
    More details: http://cadpanacea.com/node/34
    R.K. McSwain
  1. HEC-RAS Import
    By BenE in forum AutoCAD General
    Last Post: 15th Aug 2008, 04:59 pm
  2. db import to bom
    By metaldan in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Mar 2008, 09:02 pm
  3. How to import DWG in VIZ
    By kedar in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jan 2008, 04:29 pm
  4. Can't Import into 3DS
    By Cyborg771 in forum AutoCAD Drawing Management & Output
    Last Post: 1st May 2006, 06:40 pm
  5. import p x y z d
    By motee-z in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Feb 2006, 05:22 pm
