tuxarut Posted January 22, 2009 Share Posted January 22, 2009 Hello I am trying to unfold this part into a flat pattern to be cut. The top radius is 6" and the bottom radius is 4". I attached a screen shot of the part as well as the solidworks file (rename the .zip extension to .sldprt). I made the solid part, added a variable fillet then shelled what I didn't need. I am unable to unfold it to a flat. If anyone has a better Idea for developing the flat I am open to suggestions. The customer is wanting this asap and I am under the gun. Please help. part.zip Quote Link to comment Share on other sites More sharing options...
ramsay Posted January 22, 2009 Share Posted January 22, 2009 what version of solidworks are you using ? How exactly did you make the part did u make it out of a solid piece then shell it out ? Tryed opening the zip file but cant open it up ? Hello I am trying to unfold this part into a flat pattern to be cut. The top radius is 6" and the bottom radius is 4". I attached a screen shot of the part as well as the solidworks file (rename the .zip extension to .sldprt). I made the solid part, added a variable fillet then shelled what I didn't need. I am unable to unfold it to a flat. If anyone has a better Idea for developing the flat I am open to suggestions. The customer is wanting this asap and I am under the gun. Please help. Quote Link to comment Share on other sites More sharing options...
tuxarut Posted January 22, 2009 Author Share Posted January 22, 2009 what version of solidworks are you using ?How exactly did you make the part did u make it out of a solid piece then shell it out ? Tryed opening the zip file but cant open it up ? You need to rename the zip extesion to a .sldprt to open in solidworks. I use 2008. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted January 22, 2009 Share Posted January 22, 2009 the zip file is corrupt and will not open. I dont think you can unfold a solidpart unless you are making it in the sheet metal function. That part can't be bent, it needs to be formed so the metal can stretch. Here is an example for you. I drew a solid block and created a variable radius corner, tried to use the convert to sheet metal function and got the error below. I think what you need to do is create a forming tool and apply it to a sheet metal piece. I dont have any experience with this. what is the client looking for? Quote Link to comment Share on other sites More sharing options...
shift1313 Posted January 22, 2009 Share Posted January 22, 2009 i got the file to open renaming it like stated above. also as a note, my first screen shot and second screen shot contain two different bends Quote Link to comment Share on other sites More sharing options...
shift1313 Posted January 22, 2009 Share Posted January 22, 2009 sorry man but i dont think its possible. I am vairly certain a variable radius sheet metal piece needs to be formed. Im not sure if 08 has forming tools but im pretty sure they do. Does your client need a way to bend this? Quote Link to comment Share on other sites More sharing options...
tuxarut Posted January 22, 2009 Author Share Posted January 22, 2009 We are the ones that will be forming. We are going to be bump bending the piece to the different radius's. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted January 22, 2009 Share Posted January 22, 2009 so what do you need the flat pattern for? Im just trying to get a feel for what you need. If you were able to flatten that without the metal distortion it wouldnt be your starting piece. you would have a rectangle to start Quote Link to comment Share on other sites More sharing options...
tuxarut Posted January 22, 2009 Author Share Posted January 22, 2009 The top is tapped down so It wouldn't be a rectangle. I am producing the flat to be cut here and bent. Quote Link to comment Share on other sites More sharing options...
stevsmith Posted January 22, 2009 Share Posted January 22, 2009 Argggh. I wish I had solidworks back so I could show you. I need the buttons infront of me to remember. It has been over 2 years. Quote Link to comment Share on other sites More sharing options...
stevsmith Posted January 22, 2009 Share Posted January 22, 2009 Low and behold http://uk.youtube.com/watch?v=iaJnetmfizc Hope this helps Shifty, have you ever used cad digest before. Thats where i learned everything about SW. Also, you need to give it a thickness before it converts to sheet. It looks like you have drawn a block and tapered the ends Quote Link to comment Share on other sites More sharing options...
stevsmith Posted January 22, 2009 Share Posted January 22, 2009 The top is tapped down so It wouldn't be a rectangle. I am producing the flat to be cut here and bent. You would not be able to fold that shape in one go. It would have to be either. 1) folded in several stages to gain a progressive curve (like sq to round ducting only with more folds). 2) a special press and die made specifically for that item (likely to be expensive). 3) moulded (contact corus steel). Quote Link to comment Share on other sites More sharing options...
tuxarut Posted January 22, 2009 Author Share Posted January 22, 2009 I don't have SW on my computer now, but I will give that a try tonight. Quote Link to comment Share on other sites More sharing options...
cedar Posted January 22, 2009 Share Posted January 22, 2009 try a "Lofted Bend" Quote Link to comment Share on other sites More sharing options...
JD Mather Posted January 22, 2009 Share Posted January 22, 2009 You want planes, cylinders or right circular cones. Looks like that fillet could be done with a cone. Shell will not result in a proper sheet metal part on this geometry - the end cuts will not be perpendicular to the flat. When I get a chance I'll work up an example. Quote Link to comment Share on other sites More sharing options...
tuxarut Posted January 22, 2009 Author Share Posted January 22, 2009 I think you are right, the way I drew it will not produce a flat. I will try drawing this without shelling and try some options you guys have thrown out. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted January 22, 2009 Share Posted January 22, 2009 i still havent found a way to do it. Maybe lofted bend would get you close but i cant find anything to exactly replicate what you want because i dont think SW cand stretch the metal. ill play with it again when i get the chance Quote Link to comment Share on other sites More sharing options...
ramsay Posted January 22, 2009 Share Posted January 22, 2009 Still learning solidworks myself only way i could do anything like is sketching bends in manualy 6 degree at at time. Quote Link to comment Share on other sites More sharing options...
tuxarut Posted January 23, 2009 Author Share Posted January 23, 2009 Low and behold http://uk.youtube.com/watch?v=iaJnetmfizc Hope this helps This looks like its what I need, but I am using 2008. Quote Link to comment Share on other sites More sharing options...
tuxarut Posted January 23, 2009 Author Share Posted January 23, 2009 You would not be able to fold that shape in one go.It would have to be either. 1) folded in several stages to gain a progressive curve (like sq to round ducting only with more folds). 2) a special press and die made specifically for that item (likely to be expensive). 3) moulded (contact corus steel). You are right, we will be doing what we called bump bending to produce to two radius's. Quote Link to comment Share on other sites More sharing options...
