Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Full Member Jaelin's Avatar
    Jaelin's Computer Details
    Windows XP (Service Pack 2)
    HP Workstation xw6200 (piece of junk :) )
    Intel Xeon CPU 3.40ghz
    4GB
    NVIDIA Quadro NVS 280 PCI 64MB
    300GB
    HP p930 & HP 1955
    Civil 3D 2009
    Dec 2008
    Bartow, Florida
    86
    Quote Originally Posted by darn-net View Post
    Jaelin
    What command is shown on command line when you run this "Rescale Blocks/Text"?
    No command shows up. I can't find a command input for it.
    "If you don't like change, you're going to like irrelevance even less." ~General Eric Shinseki, Chief of Staff, U.S. Army~
  2. #12
    Junior Member
    AutoCAD 2009
    Jan 2009
    12
    Thank you to everyone. This is a great and very helpful forum.
    5.Erase all except one. Change object size. Re-array the object.
    This is what I did. It fits in with my current skill level, just above zero. Thanks to everyone for pointing the way. I will next learn about blocks as that seems very promising from the view point of my begining familiarity.
    Quote Originally Posted by Jaelin View Post
    If they are blocks:
    In Civil 3D Land Desktop Companion 2009 I have a command under my Utilities/Edit Menu that is Rescale Blocks/Text. This command scales everything in place by a certain scale factor. I'm just not sure if this a standard AutoCAD command or a LDC command. I'm thinking it may be a LDC command only but not sure. This command is what I use to scale my blocks or text.
    I don't know what "Civil 3D Land Desktop Companion 2009" is. But it sounds promising. After teaching myself Blocks, I will refer back to this.
  3. #13
    Senior Member TimZilla's Avatar
    AutoCAD 2009
    Mar 2008
    North Carolina
    120
    Default wish I knew
    Quote Originally Posted by Sudan View Post
    Newbie here, I'm making a ceramic floor tile design.
    Thanks to people on this forum I can perform the scale command on a single object. I now want to scale multiple objects all at once.
    My drawing is a chess board, simple grid of 1" squares on layer "CHESS".
    At every intersection of each four squares, where their corners meet up, i.e., the lines cross, I have one small decorative hexagon of 1/4" on the side. The center of each of these small 1/4" hexagons is exactly on the intersections of the big 1" squares. All and only these small decorative hexagons are on their own layer "HEXA".
    I want to scale the small decorative hexagons from 1/4" on the side down to 1/8" on the side. I was able to QSELECT all the objects in layer HEXA. I was then able to scale down all at once to the correctly desired new size of 1/8" on the side
    BUT! (you knew this was coming) The centers of each hexagon moved. Each moved closer to the particular hexagon object that I performed the SCALE command on. It was as if the position of the selected hexagons got scaled too.
    I know I can perform SCALE command on each object by itself and get to where I want to be. I just want to know if I can do this on multiple selected objects at once and have the scaled objects maintain their center point after scaled.
    Thank you.
    I have one that will let you select a block. then you can either scale all blocks in the drawing in place, or highlight a part of the drawing without isolating and it will scale only that block you want.
    but,
    without it being a block, this lisp routine would somehow have to determine the center point of all the objects you selected. I just don't see that happening. I pray that someone is smart enough to make this, because I have needed it a few times. Always remember to make blocks!
    I have been burned a few times by not doing so!
    I thank all of you who take time out of your life to help me. I hope this is not asking to much of those who do help, but could you give detailed instructions because I know only the basics. -Thanks a million
  4. #14
    Forum Newbie TJKawaguchi's Avatar
    TJKawaguchi's Computer Details
    Windows 7
    Intel Xeon(R) W3505
    12gb
    AutoCAD 2015
    Aug 2012
    Portland, OR
    8
    To fix this, I edited the block and moved the center of the block to 0,0. Originally the first attribute (of 4) was at 0,0. Then when I scaled them from 192 to 96 they were all in the right place.
  5. #15
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,603
    Another method delete all items except 1 at bottom left, rescale then just use ARRAY all done no need for a lisp.
  1. Move objects between layers
    By itsme_dougp in forum AutoCAD Beginners' Area
    Last Post: 31st Oct 2011, 06:58 am
  2. COPY or ** COPY ** - Copy and Stretch, Move, Rotate, Scale & Mirror objects
    By Andrew1979 in forum Tutorials & Tips'n'Tricks
    Last Post: 27th Jul 2009, 07:36 am
  3. move objects using VBA
    By rhs in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Jul 2008, 09:55 am
  4. Move multiple Attributes without using Grips
    By icevapor in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Mar 2008, 04:05 pm
  5. Objects move in two directions
    By siderus in forum AutoCAD Beginners' Area
    Last Post: 13th Jan 2006, 08:22 pm
