Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 58
  1. #21
    Forum Newbie
    AutoCAD 2008
    Aug 2009
    2
    Hi Brynn,
    I'm just starting myself the plap map project, how long did it take you to complete? I finish entering all my survey point with bearings but I am a bit confuse when they also mentioned
    ~ The line connecting the points is a right-of-way line and serves as the west boundary of SW Oleson Rd, which is 80 ft. wide. Is this a road I need to do at this point? Not so clear what I am reading.
    I can use your help
    I'm using Autocad 2008
  2. #22
    Senior Member Car5858's Avatar
    Car5858's Computer Details
    Win7
    Gateway Sx2800-3
    Intel Quad Core 2.33
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    Car5858's Discipline Details
    retired, disibality
    See details below.
    Tutor, AMA glider competitions.
    AutoCAD 2010
    May 2009
    Hammond
    373
    This is additional information that was provided.
    Yes it is a road that you will have to do. Did you read the complete instruction set before starting the project? This helped me to understand all that was needed while drawing the plat map. Also checking off each step will help you keep track of where you are in the instructions.
  3. #23
    Super Member
    AutoCAD pre 2000
    Nov 2008
    577
    Quote Originally Posted by Scan1953 View Post
    Hi Brynn,
    I can use your help
    From what you have cited, I am as confuesed as you are. Go to whoever gave you the project and have them explain about the line.
    We have roads here in which the centerline does not always go down midway between the R/W lines. Thus you need to talk to some one with your business.
    Wm.
  4. #24
    Forum Newbie
    AutoCAD 2008
    Aug 2009
    2
    No I have not read the whole project but I will now...
    Also, POB is measured from BM#8332 is it the same as the coordinates for the benchmark 1421334.93,783207.62 ? Why 8332?
    Bear with me, I'm a very visual person so the more information I read the more confusing it gets sometimes.
    Thanks
  5. #25
    Win7
    Gateway Sx2800-3
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    retired, disibality
    See details below.
    AutoCAD 2010
    May 2009
    Hammond
    373
    Thanks
    The POB is measured from the benchmark. Read through the instructions again and take notes. I think you are missing the answer that you are looking for.
  6. #26
    Super Member
    AutoCAD pre 2000
    Nov 2008
    577
    Well, a number of years ago, used to go to the Wattles classes on deeds. Became registered not long afterwards, and one thing Gurdon mentioned was to cite a few deeds in order such that you do not have to shuffle papers around to find a reference item. Sounds nice and cozy, but never got into the routine. You answer may be too far into the pile of papers for you then have to go back and re-read the earlier stuff once again.
    Wm.
  7. #27
    Forum Newbie
    AutoCAD 2008
    Nov 2009
    1
    It seems I googled the right thing. I'm also taking the Penn course and have been doing pretty well till I got to this part. Truth be told I had never heard of a "plat" and really thought it was a made up name for the course.
    I am a sheet metal worker and have been for the past 22 years and I am now getting into the Cad side of things so I thought I'd take the course to get me started in the right direction. So far so good but the survey stuff is not what we do here at all and I was thrown off by the directional input methods.
    I googled the Oleson Village and found the site and the others struggling with the same thing. I just want to thank you all, the questioners , and the problem solvers. All of you have helped me ,not only with the startup of this test but in finding this site. The only other forum I go to is a Moe Norman golfing web forum and it is set up exactly like this one.
    I've signed up for the site and hopefully in a few months I'll be able to help someone the way you all helped me.
    I wonder if the folks who posed the ?'s about this test are still frequenting this forum or did they get their answers and go?
    Anyway thanks again for getting me started in the right direction and I know where to go if I get stuck again, thanks. Dan Bassett
  8. #28
    Junior Member autocad2010's Avatar
    AutoCAD 2006
    Apr 2010
    11
    I'm also doing the same project, almost done.
    Did any of you here finish this project? can we PM each other here?
  9. #29
    Win7
    Gateway Sx2800-3
    8GB
    Intel 4500
    Seagate 500 gb
    Passport usb 500 gb
    HANNspree 22"
    See details...
    retired, disibality
    See details below.
    AutoCAD 2010
    May 2009
    Hammond
    373
    Yes I finished the course in Aug of 09.
    Has this thread helped you out?
  10. #30
    Junior Member
    AutoCAD 2010
    Nov 2011
    17
    Im not sure I'll get a reply to this since everyone seems to have finished this test so long ago but Im gonna give it a shot. So I have done ok so far with this test. Esspecially that it threw me for a loop not ever even being taught much in this subject. I have drafted the map with trees and all (yes the s44 tree is still a typo. At least thats what Im guessin the prob is givin all the other typo's in this course). I am at the point where Im told to create a north arrow and place it on the map..... Is there a sopecific style and size to this arrow? Where exactly is it placed? This would be much better had we been taught more on this type of engineering.... Thanks to anyone for the help. Eric
  1. Curve in Plat Map Coordinates
    By ljstevens in forum AutoCAD General
    Last Post: 11th Mar 2008, 12:21 am
  2. Reading a plat
    By Son of Aslan in forum AutoCAD General
    Last Post: 17th Feb 2008, 06:05 pm
  3. Scanned Plat
    By UsedCrayons in forum AutoCAD Beginners' Area
    Last Post: 17th Feb 2007, 01:01 am
  4. Trying to show bearings/distances on plat.
    By huntman23 in forum AutoCAD Drawing Management & Output
    Last Post: 12th Mar 2006, 11:09 pm
  5. Plat Mapping Curve Table
    By GIS_Guy in forum AutoCAD Beginners' Area
    Last Post: 16th Mar 2005, 06:17 pm
