autocad 2009 problem
iamlegend
Just bought autocad 2009, installed it etc etc.
when i launch i get a fatal error: unhandled access violation reading 0x0000 at 60c068h
Could not load plcfmg.dll
Anyone know what too do?
first, welcome to the forum....
ok.. some fatal error occurs?
i guess you should re-install the software again..
then try it. if the problem still occurs.. i dont know anymore of that maybe someone here might help you.. but you could give it a shot.. just try to re-install it..:)
hope it may help
I searched my AutoCAD 2009 folder, my Documents and Settings folder and my Windows folder and could not find the file that you mention (plcfmg.dll).
I even "Googled" the file name and the only worthwhile mention of it was a link back to your post. Is it a file on the installation disk itself? Part of the installation process?
Errors like this can occur if AutoCAD is not installed properly. As previously suggested you may have to uninstall and then reinstall AutoCAD.
Other possibilities include:
-a virus.
-a conflict with your anti-virus program (which one are you running?).
-a conflict with another application? What else is running in the background other than your anti-virus program?
By the way, after you loaded AutoCAD did you load service pack 2?
  • 4 months later...
