Results 1 to 4 of 4
    Forum Newbie
    ktrides2's Computer Details
    XP
    Architecture 2008
    Jan 2009
    Tampa, Florida
    7
    Default Same set up different results from project templates
    I have two projects setup that I use for templates when you create a new project:
    One (24x36) works perfectly by setting up sheets in the newly created project.
    The other one (30x42) sets up the sheets in the original template file - not the new one.
    Here are the setups for each, what am I missing?
    THANKS SO MUCH!!! I am looking through other threads to see if I can pay it back
    Super Member
    Architecture 2009
    Aug 2007
    Northglenn, Colorado
    713
    is it pulling your sheet templates from the same file? and are both the 24X36 and 30X42 in that same dwt file?
    Forum Newbie
    XP
    Architecture 2008
    Jan 2009
    Tampa, Florida
    7
    No each set has its own dwt template
    Super Member
    Architecture 2009
    Aug 2007
    713
    have you tried creating a new sheet set to make sure it is pulling from the right template? I suspect that you created the 30X42 project template first? Is that a right assumption? sorry for so many questions, just trying to help get to the bottom of your prob.
  1. Lighting and best results
    By BenGoble in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th May 2007, 07:05 pm
  2. Lighting and best results*
    By Lazarus in forum AutoCAD 3D Modelling & Rendering
    Last Post: 25th May 2007, 02:18 pm
