Results 1 to 6 of 6
    Forum Newbie Shinichi's Avatar
    LDD 2004
    Feb 2009
    2
    Default Cross section display in land desktop
    HI,
    This is my first post here. I am a new member. I've read a lot of threads here and I've learn a lot..thnks to evry1.
    Here's my question: How can I change the display of my cross section taken from a surface I've made. I've already created contours and my goal is something like the attach sketch belowdid the attachment shows?)
    Quantum Mechanic
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,139
    Here in Aus our cross section are better than grid based as per US but I can not really tell what you are trying to achieve is it just a scale thing. if so change scale ?
    Also maybe this should be in the Civil 3D section of the forum.
    Super Member rustysilo's Avatar
    rustysilo's Computer Details
    WinXP
    Civil
    rustysilo's Discipline Details
    Senior CAD Draftsman
    Civil
    Civil 3D 2008
    Jul 2007
    Jacksonville, FL - USA
    1,458
    Ehhh. What's the difference?
    Oh you mean the vertical exaggeration? If I remember right that is based on your drawing scale (for horizontal) as well as the settings when you create the sections for vertical exaggeration. I don't have Land Desktop loaded so I cannot verify for you.
    "Constantly choosing the lesser of two evils is still choosing evil." ~ Jerry Garcia
    flickr |
    work | blog | creed
    rustysilo's tips & tutorials
    WinXP
    Civil
    Civil
    Civil 3D 2008
    Jul 2007
    1,458
    Quote Originally Posted by BIGAL View Post
    Why are Aus cross sections better? Could you post one as I have never seen how you do it there.
    flickr |
    work | blog | creed
  5. #5
    LDD 2004
    Feb 2009
    2
    Hi guys
    Sorry 4 dat one
    heres really wat im trying to achieve:
    1. to display the vertical and horizontal scale of the cross section(e.g. vertical scale 1:20, horizontal scale 1:100) Im using metric units
    2. To plot(print) it wid the scale being displayed
    this it wat I've than:
    1. I;ve created contours of the river based on survey data(estimated lenght=4km)
    2. imported quick section into the drawing and put grid on it
    my problem is i dont know wat is the scale(vertical/horizontal) of that section. i want to print it wid the scale i want and is being displayed
    is that posibble in LDD 2004?
  6. #6
    WinXP
    Civil
    Civil
    Civil 3D 2008
    Jul 2007
    1,458
    When you print you will use the horizontal scale. For the vertical you must change the vertical exaggeration. If you are not sure how to do this go to the HELP file and type "vertical exaggeration" and you should find how to set it in the results.
    I'm fairly sure you set this when you create the sections, but it's been so long I cannot remember. When you create the sections look for "vertical scale" or "vertical exaggeration".
    flickr |
    work | blog | creed
  1. doing cross section
    By emimotul in forum AutoCAD Beginners' Area
    Last Post: 26th Dec 2011, 01:59 am
  2. cross section
    By Mirna in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Jan 2011, 09:43 am
  3. can i get help with a cross section
    By fresh in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 3rd Jan 2010, 12:04 pm
  4. Cross Section Analysis
    By Lazer in forum Autodesk Inventor
    Last Post: 28th Sep 2007, 07:55 pm
  5. Cross-section in Autocad2007
    By alyona in forum AutoCAD Drawing Management & Output
    Last Post: 10th Apr 2007, 09:17 am
