AckermanFancy Posted February 6, 2009 Share Posted February 6, 2009 Hello All, Does anyone know of a free DWG to JPG conveter? I don't use it enough to justify paying $75 for one. If not is there anyone willing to convert a file for me? I would need it 1:1 scale. Regards, AckermanFancy Quote Link to comment Share on other sites More sharing options...
dbroada Posted February 6, 2009 Share Posted February 6, 2009 not sure about your version due to its age but you should be able to install a JPG plotter using the add plotter function. Look for raster image type in the list. I am sure we used to do JPGs that way with release 14. Once installed you just plot the drawing to file. Quote Link to comment Share on other sites More sharing options...
wannabe Posted February 6, 2009 Share Posted February 6, 2009 Jpegout..... Quote Link to comment Share on other sites More sharing options...
Phiphi Posted February 6, 2009 Share Posted February 6, 2009 Hello All,Does anyone know of a free DWG to JPG conveter? I don't use it enough to justify paying $75 for one. If not is there anyone willing to convert a file for me? I would need it 1:1 scale. Regards, AckermanFancy Plot a PDF format, use free PDF-XChange Viewer from .docu-track.com/downloads/users/ to open. Select File\Export\Export to image\Image type. Quality is number one. P/s: Please add www to that link. Quote Link to comment Share on other sites More sharing options...
dbroada Posted February 6, 2009 Share Posted February 6, 2009 Jpegout..... I didn't think that command was around that long ago. I only have reference books for release 11 & 12 and it wasn't available then. Quote Link to comment Share on other sites More sharing options...
Seneb Posted February 6, 2009 Share Posted February 6, 2009 At the very least, you can size up what you want within the window, press Alt + Print Screen, then paste it in Microsoft Paint. Not a quality option, but it's definitely a freebie. Quote Link to comment Share on other sites More sharing options...
uddfl Posted February 6, 2009 Share Posted February 6, 2009 OP, what version are you using? Quote Link to comment Share on other sites More sharing options...
macareewall Posted February 9, 2009 Share Posted February 9, 2009 I'll be gald to convert a file for you, I bought AutoDWG DWG to JPG converter last month, or you can have a 15 days free try on that link. http://www.autodwg.com/DWG2Image/ Quote Link to comment Share on other sites More sharing options...
tkelly Posted February 26, 2009 Share Posted February 26, 2009 JPG printer is supported by Autodesk in software itself above 2007 version . The printer is "publish to webjpg.pc3." This should help you to print .JPG with desired linetype and .CTB used. If you have lower version then print to .PDF file using pdf printer and then convert PDF to JPG with required resolution. Tom Quote Link to comment Share on other sites More sharing options...
Se7en Posted March 10, 2009 Share Posted March 10, 2009 I recommend Ghostscript as a printer: Ghostscript is free. You can either print to Postscript file and convert that to many different formats (like PDF, PNG, TIFF, HPGL...) or you can use a combination of Ghostscript and Redomon to print directly to a format (like PDF, PNG, TIFF, HPGL...) or you can even use AutoSpool. It would also be a good idea to alter the ghostpdf.ppd to add page sizes and etc. (find it in the lib dir) file BEFORE installing a Ghostscript printer driver on you system. Quote Link to comment Share on other sites More sharing options...
Zorg Posted May 1, 2009 Share Posted May 1, 2009 Set your autocad background to white and take a screen dump in the model space of your selected area. Lame, but easy. Quote Link to comment Share on other sites More sharing options...
Zorg Posted May 1, 2009 Share Posted May 1, 2009 'JPGOUT' - neat Quote Link to comment Share on other sites More sharing options...
roxrc Posted May 6, 2009 Share Posted May 6, 2009 i use pdfcreator Quote Link to comment Share on other sites More sharing options...
David Bethel Posted May 6, 2009 Share Posted May 6, 2009 Depending on the release that you are using, look into the saveimg command. Each release had differing formats to export in. jpgout wasn't around until after 2000. -David Quote Link to comment Share on other sites More sharing options...
Tankman Posted June 9, 2010 Share Posted June 9, 2010 'JPGOUT' - neat Use the Add-a-Plotter wizard (PLOTTERMANAGER) to add a raster "printer" - eg. for the TIFF format: use This Computer, select Raster File Formats (as Manufacturer) and under Model select TIFF (or PNG, JPG...). Raster image size is unitless (in pixels, not inches or mm) - to increase resolution of the raster file (in pixels) set a "larger paper size". You can create a custom "paper" size for this "printer" - increase this paper size to achieve higher resolution (more pixels in the resulting raster file). The DPI (dots-per-inch) value is usually fixed (e.g. 100 dpi) so to get 2000 pixel resolution you will have to set 2000/100 = 20 inches page size. In higher AutoCAD versions you can use directly pixels so you don't need to recalculate page size values. Under Device settings you can set the color depth (for color formats) - fewer colors means smaller files. You can also export DWGs to other raster formats - CALS, JPG/JPEG, BMP, PNG, TGA, PCX. All standard print settings (line weights, plot styles...) will apply. And you can also use standard AutoCAD batch plot operations for these exports. Please note that you cannot control resolution/quality for the direct JPGOUT, PNGOUT and similar commands. Quote Link to comment Share on other sites More sharing options...
