susana Posted February 6, 2009 Share Posted February 6, 2009 Hello:) , I have problems quand i export a layer of autocad 3d map 2008 (as a shapefile), because when i export it and i insert that in a new file autocad, all this (by default) it appears all in white (loosing his natural color). I had copied this as a shape file, changing his attributes (color, linetype, lineigth...and others) but when i see them on a new file, it's all in white. Do i have to change something when i export or i must change something in the new file (or during le process de import le shape)? Can i change an attribute (as his color) of a shapefile in a notepad version? Quote Link to comment Share on other sites More sharing options...
CarlB Posted February 6, 2009 Share Posted February 6, 2009 I see others have this problem, so it's not just you http://discussion.autodesk.com/forums/message.jspa?messageID=5896166 Quote Link to comment Share on other sites More sharing options...
