viriato79 Posted February 8, 2009 Share Posted February 8, 2009 I´m Tyrying to erase a layer but It cannot be deleted: It is not the 0 layer, or a x-ref layer and there are no objects in that layer. Probably there was a block in that layer but it was erased. How can I erase it? Thanks Quote Link to comment Share on other sites More sharing options...
lpseifert Posted February 8, 2009 Share Posted February 8, 2009 Try Laydel Quote Link to comment Share on other sites More sharing options...
viriato79 Posted February 8, 2009 Author Share Posted February 8, 2009 Try Laydel Command: laydel Select object on layer to delete or [Name]: Terciarias *Invalid selection* Expects a point or Last/Name]: Still can´t erase. Quote Link to comment Share on other sites More sharing options...
lpseifert Posted February 8, 2009 Share Posted February 8, 2009 Laydel [enter] N [enter] ... Quote Link to comment Share on other sites More sharing options...
jammie Posted February 8, 2009 Share Posted February 8, 2009 By default LAYDEL requires you to select an object. Select object on layer to delete or [Name]: Terciarias Type N instead and select the required layer(s) from the drop down list Command: laydel Select object on layer to delete or [Name]: N Just some poinys on LAYDEL 1. LAYDEL cannot erase the current layer 2. LAYDEL will redefine any blocks that contain nested objects on the layer to be deleted Quote Link to comment Share on other sites More sharing options...
DECHAL Posted February 9, 2009 Share Posted February 9, 2009 Try PURGE command!!!!!! DECHAL Quote Link to comment Share on other sites More sharing options...
skipsophrenic Posted February 9, 2009 Share Posted February 9, 2009 Try PURGE command Smoetimes even though the block isn't being used if it is still in the drawing file so as can be inserted at a later point the layer assosciated with it can't be deleted. Quote Link to comment Share on other sites More sharing options...
DECHAL Posted February 9, 2009 Share Posted February 9, 2009 But Viriato79 says "no objects in that layer". So Purge should work! May have to purge twice. First would goose the block and the second would goose the layer. ""Maybe"... DECHAL. Quote Link to comment Share on other sites More sharing options...
skipsophrenic Posted February 9, 2009 Share Posted February 9, 2009 Yeah even if the blocks not inserted but in the memory of the drawing, then it sometime won't allow you to get rid of the layer "Just in case" Hence why i was agreeing with you - Sorry for the confusion Quote Link to comment Share on other sites More sharing options...
bonehead411 Posted February 9, 2009 Share Posted February 9, 2009 A couple of purges should work, as DECHAL suggests, unless.......... someone has to ask the stupidly obvious question, and it may as well be me. Is the layer 'defpoints'? Quote Link to comment Share on other sites More sharing options...
viriato79 Posted February 9, 2009 Author Share Posted February 9, 2009 Ok, thanks everybody. I did purge but, purge and purge all buttons were disabled. but when I right click at layers in that windows I could purge the layer Terciarias. Quote Link to comment Share on other sites More sharing options...
DECHAL Posted February 9, 2009 Share Posted February 9, 2009 Another "stupid" question. The layer your deleting is it your current layer?????????? Quote Link to comment Share on other sites More sharing options...
