coplanar line segments over line segments
Spiderguy
Hello!
I have a question, there (at one time) was a command for removing multiple lines that were over (stacked) one another on the same plane. Does anyone know about what I am asking? I can select a line delete it another is there, can delete it, another is there, this can go on and on until the last one is selected. I run into this often, where people who do not use CAD often have done some drawings. There was a tool that fixed the drawing for you, I can't remember what it was called, nor can I seem to find it in AutoCAD help.
Thanks,
Matt
Express > Modify > Delete duplicate objects
If it doesn't seem to work properly, try setting Pickfirst=0 prior to running the command
