Flat Pattern Sheet metal.
Rob123
Ive tried to make a Flat Pattern of a conical shape, but the only thing it does is turn it to a pancake:x . is there any way i can make a decent flat pattern Without creating a gap.
So could anyone help me with this problem,
Thanks!
Couldn't you at least supply some dimensions?
I cut off part of the top anticipating that as your next question.
Pull down the EOF marker.
Ok i attached a file this time :D, this is my problem :) , in the last post i attached a picture. this happens when i use revolve. then convert to sheet metal , set the thickness in sheet metal defaults. and pres flat pattern.
naamloos.zip
