More info:
I have two setups for PDF in the SSM. One is for DWG to PDF and the other is for Adobe PDF. The DWG to PDF plots all sheets together in one tidy PDF, but the line weights are messed up. Some of the text is much darker than it should be, but the properties within AutoCAD are the same. Sometimes it is within the same paragraph of text on different lines. If I use Adobe PDF, it plots the first sheet to a PDF file perfectly, then publishes the rest without outputting them anywhere. They're just gone.
I've also tried publishing to DWF to then convert to PDF, but it creates horizontal black lines on every sheet.
