Results 1 to 4 of 4
    Senior Member
    JamFam's Computer Details
    Windows XP Pro 32 bit
    AutoCAD 2010
    Mar 2006
    British Columbia, Canada
    115
    Embarrassed Moving image to layout template
    So I have approx. 30 drawings all done to full scale (in metric) but not all were done the same way. I am learning how to set up a drawing but I haven't quite got the hang of that. Anyways I found an architectural template within my autocad 2000, made some adjustments to it and saved it as a dwt. What I want to do is print out my images with the newly created dwt template as the framework for all printed drawings. How do I do that???
    Thanks
    JamFam
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,024
    Open the architectural template. You should be in a Layout. Switch to model space. Insert one of your drawings. Switch back to your layout and create a viewport. You should see your drawing now. Right?
    Normally you would start your new drawing by opening one of your templates.
    Senior Member
    AutoCAD 2010
    Mar 2006
    115
    Wink
    So here is what i ended up doing before getting to read your post. I opened the architectural title block which I adapted to my project, sorry for misleading you and calling it an architectural template. Anyways I opened it which was in/on it's own tab next to model, layout1 and layout2, then I highlighted the "template" and pasted it to a blank model space area, there I could make the necessary changes to the description area of the "Template". I opened up a drawing, clicked on layout1 and the drawing was there waiting to be printed, then I highlighted the "Template" and copied with a base point. I went to my drawing in layout1 and pasted the "Template" as a block and moved the "Template" to the precise area of the Layout1 image and over lay the "Template", then printed. I did this for all 30 odd images. I then could create a PDF from what was seen within the layout1 showing the drawing with the "Template", the end result is a drawing with the desired title block "Template". I'm sure there must be a much faster and much easier way, but this is what worked for me. I would appreciate a tutorial on how to use a title block correctly as I'm sure I will be doing more of these kinds of drawings.
    Thanks ReMark
    JamFam
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,024
    You went through all that for 30 drawings? It must have been a slow day.
  1. Moving Layout Tabs
    By Simple153 in forum AutoCAD Drawing Management & Output
    Last Post: 8th Sep 2009, 11:25 pm
  2. Centering my template in Layout space
    By XBR1 in forum AutoCAD Drawing Management & Output
    Last Post: 30th Jul 2007, 05:12 pm
  3. Image in Layout
    By cad_monkey in forum AutoCAD Drawing Management & Output
    Last Post: 11th Aug 2006, 04:58 pm
  4. Drawing Template vs. Settings Template?
    By umop-3p!sdn in forum AutoCAD Beginners' Area
    Last Post: 20th May 2006, 01:09 am
  5. Template / Image
    By jaykappy in forum AutoCAD Beginners' Area
    Last Post: 25th Jan 2006, 10:45 pm
