monk Posted July 20, 2014 Share Posted July 20, 2014 Bit of an old thread, I too had this problem. I started to learn lisp for this reason. I have a little tool called "xref process" I use it to change All text colours All hatch colours run setbylayer Set ltscales set all objects CELTSCALES Very easy to code saves time. Most of my routine is based around "SSGET" and plain old command "._CHANGE" Quote Link to comment Share on other sites More sharing options...
ktolle2 Posted July 28, 2014 Share Posted July 28, 2014 Did you find an alternate solution for newer versions of AutoCAD? I am hitting the same wall as you. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 29, 2014 Share Posted July 29, 2014 (edited) exactly my sentiment, I have become my company's CAD janitor, spending hours cleaning up client or other vendor provided cad files with way too many cooks in the stew. Thus ending up with duplicate text styles with different stylenames. if the text were in the open as text or mtext i'd have no problem spending the time with qselect to 'move' them to a single stylename, but these text styles are embedded in block symbol attributes. Check on Lee Mac's website, he has lots of clever text lisps there, tha dig deep quickly. I would be surprised if he doesn't have one that will do what you need. http://www.lee-mac.com/matchtextprops.html Not to say this is the most appropriate one, though it may well be. Lots of others, that might be better suited if this doesn't work for you. Do your homework, and check them out, your time will be well spent, at the end of the day, the time and aggravation you save will be your own. Thanks Lee! Edited July 29, 2014 by Dadgad Quote Link to comment Share on other sites More sharing options...
fd2typrR Posted September 30, 2014 Share Posted September 30, 2014 It 's working:D Quote Link to comment Share on other sites More sharing options...
