Results 1 to 7 of 7
Thread: saving/printing
    abbs83
    Default saving/printing
    I am new to AutoCAD and I dont' know how to save a drawing so that it can be opened on a computer that doesn't have AutoCAD installed so I can print to a plotter. Right now I only know how to save as a .dwg, .dxf or .dwt. I usually use .dwg and occasionally .dxf but I don't know what to open the files with on a computer without AutoCAD installed. I'm running AutoCAD LT 2004. If this is posted in the wrong place please let me know, I've also never used a forum before.
    Senior Member
    not specified
    Mar 2005
    204
    If you have Adobe Acrobat you can save the drawings in a .pdf format which can be opened with Acrobat reader.
    A better option may be to use a CAD viewer program like Voloview, which would allow you to open & print the drawings. It used to be a free download, I don't know if it still is.
    If there is anything the nonconformist hates worse than a conformist,
    it's another nonconformist who doesn't conform
    to the prevailing standard of nonconformity.
    abbs83
    I have acrobat but my problem is that I don't know how to save the autocad drawing as a .pdf file. When I choose save from the File menu in Autocad my only choices to save the pic as are .dwg, .dxf, and .dwt; .pdf is not a choice. Can I convert it to a .pdf in the Voloview program you suggested? Thanks for the tip on voloview, I will look into it.
    Senior Member
    not specified
    Mar 2005
    204
    When making a PDF file from an Autocad drawing, it's not a save-as option. It's a plot option. You can set up Acrobat as a printer and choose that from the Autocad plot dialog. It then creates the PDF file.
  5. #5
    Full Member
    AutoCAD 2009
    Mar 2005
    46
    If I'm not mistaken Volo View stopped supporting dwg. files after Acad 2002. You now have to use the DWF viewer from Autodesk.
    A company called Bentley(sp?) has a viewer that you can go out and grab for free. Never used it not sure about its flexibility.
    This sounds kinda' lame but you can download what is called the Cute PDF Writer which is very easy to use and writes as a plot file
    Hope this helps.
    P
  6. #6
    abbs83
    thanks guys! I was missing the connection between plotting and saving and then needed the software to convert it, but I got it now!
  7. #7
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    Within AutoCAD go to the Add Plotter Wizzard and install the printer you wish to use -even if the printer is not phisicaly connected to the computer. Once the driver installed, from AutoCAD print as usualy but in the Plot dialog check the Plot To File box. The file will be saved. Move that file to the other computer hawing the printer -it should print normally.
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
