Results 1 to 6 of 6
    Simon
    Default Curve lines on hide
    Does anyone know the system variable on AutoCAD200 that controls the display of lines around a curve when you "hide" a 3D solid?????
    Administrator CADTutor's Avatar
    CADTutor's Computer Details
    Windows 7 Home Premium 64bit
    Asus P7P55D-E PRO
    Intel Core i7-860
    4GB PC3-12800 C8 Corsair Dominator
    NVIDIA Quadro FX 1800 768 MB
    Intel X25-M SSD 160GB
    Samsung Spinpoint 320GB
    BenQ FP241W 24" Wide
    Education
    CADTutor's Discipline Details
    Senior Lecturer (Digital Design), Landscape Architect & Web Designer
    Education
    AutoCAD 2015
    Aug 2002
    Hampshire, UK
    3,742
    Default Re: Curve lines on hide
    Er... good question. None of the display parameters from the Options dialogue seem to have any effect at all.
    Why not simply use one if the Shade options rather than use the old Hide command?
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    AutoCAD Tutorials | How to add images to your posts | How to register successfully | Forum FAQ
    Super Moderator f700es's Avatar
    f700es's Computer Details
    Windows 7 Pro (W)/Windows 10 (H)
    Dell Optiplex 9020 (W)/ Dell Inspiron 570 (H)
    Intel (W)/AMD (H)
    Intel Core i7-4770 quad (W)/AMD Athlon 2 X4 (H)
    16 GB DDR3 (W)/ 6GB DDR3 (H)
    nVidia Geforce GTX 645 (W)/nVidia GF GTX 650 (H)
    520 gb SSD 0/ 1TB 1 (W) 256 GB SSD (H)
    Seagate FreeAgent Go 320gb
    Samsung P2770HD 28" LCD and Samsung B2430 (W)/Acer 28" LCD (H)
    Facilities Mgmt
    f700es's Discipline Details
    Space Database Admin
    Facilities Mgmt
    Archibus Management, Space planning, Design
    AutoCAD 2019
    Sep 2002
    Winston-Salem, NC - USA
    5,678
    [quote author=Simon link=board=acadgen;num=1035537804;start=0#0 date=10/25/02 at 10:23:24]Does anyone know the system variable on AutoCAD200 that controls the display of lines around a curve when you "hide" a 3D solid?????[/quote]
    Try...
    DISPSILH
    from AutoCAD itself: Controls display of silhouette curves of solid objects in   Wireframe mode. Also controls whether mesh is drawn or suppressed when a solid object is hidden
    It toggles on and off  (0=off & 1=on)
    See if this helps.
    Here it is with the toggle set to 0
    Now here it is set to 1
    F7
    Please do not PM me with CAD questions. Post your question on the forum. Our users are the best out there and you'll get the best possible answer to your question.
    - http://f700es.deviantart.com/gallery/ -
    Simon
    Well done F700es, DISPSILH proved to be the one I was looking for. If you set the variable to (1) then the it will remove the lines showing the progression of the curve and instead show only the start and end of the curve.
    In answer to the question from CADTutor, I needed to print a simple line drawing to fax to a customer and so shade and render were no good.
  5. #5
    Intel (W)/AMD (H)
    Facilities Mgmt
    Facilities Mgmt
    AutoCAD 2019
    Sep 2002
    5,678
    [quote author=Simon link=board=acadgen;num=1035537804;start=0#3 date=10/25/02 at 14:06:41]Well done F700es, DISPSILH proved to be the one I was looking for. If you set the variable to (1) then the it will remove the lines showing the progression of the curve and instead show only the start and end of the curve.
    In answer to the question from CADTutor, I needed to print a simple line drawing to fax to a customer and so shade and render were no good.[/quote]
    Thanks. Glad it helped. I never knew of that varible until I saw it in a Cadalyst article (www.cadalyst.com) in their Jan. 2002 edition. IMHO a very nice monthly CAD magazine. Cheers all.
    F7
  6. #6
    billsta
    thank you, i really needed to konw that..
    couldnt figure it out for bloody years.... now i know...
    things you learn on here
