hairyuga Posted February 24, 2009 Share Posted February 24, 2009 Hey, I'm stuck again! I'm trying to find a way to use a common insertion point so that the user doesn't have too. The point of building this panel is to add dimensions and profiles to a block and then hit a "Create Panel" button to build the block. In this instance the user has already choose the dimension to create a box and pick a corner point. Well, I would like to use this corner point from the box as an insertion point for the part reference, text, and symbols (if needed). As you can see, VarPick under cmdCreatePanel is the point I'm trying to reference in for InsertionPnt under cmdWall. Thanks for your help! Private Sub cmdWall_Click() Dim InsertionPnt As Variant Me.hide InsertionPnt = ThisDrawing.Utility.GetEntity(varPick) Dim ampartref As McadPartReference Set ampartref = ThisDrawing.ModelSpace.AddCustomObject("AcmPartRef") End Sub 'Combo Box for Panel Sizes Private Sub UserForm_Activate() cmbPanelWidth.AddItem "1'-0""" cmbPanelWidth.AddItem "1'-0 1/2""" cmbPanelWidth.AddItem "1'-1" cmbPanelWidth.AddItem "10'-0" cmbPanelLength.AddItem "10'-0""" cmbPanelLength.AddItem "10'-0 1/2""" cmbPanelLength.AddItem "10-1""" cmbPanelHeight.AddItem "6""" cmbPanelHeight.AddItem "8""" cmbPanelHeight.AddItem "10""" cmbPanelHeight.AddItem "12""" End Sub 'Create Panel Private Sub cmdCreatePanel_Click() Dim varPick As Variant Dim dblLength As Double Dim dblWidth As Double Dim dblHeight As Double Dim dblCenter(2) As Double Dim objEnt As Acad3DSolid Me.hide 'get the input from user With ThisDrawing.Utility .InitializeUserInput 1 varPick = .GetPoint(, vbCr & "Pick a corner point: ") .InitializeUserInput 1 + 2 + 4, "" dblLength = .DistanceToReal(cmbPanelLength.Text, acEngineering) .InitializeUserInput 1 + 2 + 4, "" dblWidth = .DistanceToReal(cmbPanelWidth.Text, acEngineering) .InitializeUserInput 1 + 2 + 4, "" dblHeight = .DistanceToReal(cmbPanelHeight.Text, acEngineering) End With 'calculate center point from input dblCenter(0) = CDbl(varPick(0)) + (dblLength / 2) dblCenter(1) = CDbl(varPick(1)) + (dblWidth / 2) dblCenter(2) = CDbl(varPick(2)) + (dblHeight / 2) 'draw the entity Set objEnt = ThisDrawing.ModelSpace.AddBox(dblCenter, dblLength, _ dblWidth, dblHeight) objEnt.History = True objEnt.Update ThisDrawing.Regen acActiveViewport Me.Show End Sub Private Sub cmdExit_Click() Unload Me End Sub Quote Link to comment Share on other sites More sharing options...
hairyuga Posted February 25, 2009 Author Share Posted February 25, 2009 ANY suggestions or advice would be greatly appreciated! Thank You in Advance! Quote Link to comment Share on other sites More sharing options...
CmdrDuh Posted February 25, 2009 Share Posted February 25, 2009 what is your question exactly? I would use getpoint and make all my calculations from that point. Quote Link to comment Share on other sites More sharing options...
hairyuga Posted February 25, 2009 Author Share Posted February 25, 2009 Thanks for your reply. I'm new at this. I'm not sure how to refer that point? Get Point is for user input. I want the part reference to automatically insert at that point. Private Sub cmdWall_Click() Dim InsertionPnt As Variant Me.hide 'How do I get that insertion point from the corner point from Varpick??????? I want the point the user initially picks when they insert the block. InsertionPnt = ThisDrawing.Utility.GetPoint () InsertionPnt = ThisDrawing.Utility.TranslateCoordinates(InsertionPnt, acUCS, acWorld, False) Dim mpartref As McadPartReference Set mpartref = ThisDrawing.ModelSpace.AddCustomObject("AcmPartRef") mpartref.Origin = InsertionPnt End Sub[ Quote Link to comment Share on other sites More sharing options...
