Results 1 to 8 of 8
    Full Member
    not specified
    Jun 2005
    Edinburgh, UK
    47
    Default Error with OSNAP
    Hi!
    A wee problem with OSNAP here. I can't seem to get OSNAP settings on. Error message "Unable to set variable: SNAPUNIT" comes up every time I click on the OK button.
    Any ideas?
    Senior Member Dommy2Hotty's Avatar
    AutoCAD 2007
    Mar 2004
    Homer Glen, IL
    350
    try the command OSMODE. I use a value of 255.
    AutoCAD 2005
    ADT 2005
    Full Member
    not specified
    Jun 2005
    Edinburgh, UK
    47
    Thanks!
    Seems like OSMODE does the same thing as the OSNAP command, but in a non-graphical way. Am I right?
    The thing is now, OSNAP command still gives the same error message. Changing OSMODE value would select/deselect certain snap modes, but I can't do it graphically through the OSNAP dialogue window.. which is a bit annoying.
    AutoCAD 2007
    Mar 2004
    Homer Glen, IL
    350
    When you go into the OSNAP dialog box, under the "Snap & Grid," what are your Snap X spacing and Snap Y spacing set to?
    AutoCAD 2005
    ADT 2005
  5. #5
    Full Member
    not specified
    Jun 2005
    Edinburgh, UK
    47
    Hmmm... all seem to be set to 0...
    Aaaah! Doh! Now that I've set the spacing to 10 everything works. Hmmm... one last question though; how did it get set to 0 to begin with?
  6. #6
    AutoCAD 2007
    Mar 2004
    Homer Glen, IL
    350
    Couldn't say for sure...could be from a LISP file...
    AutoCAD 2005
    ADT 2005
  7. #7
    Full Member
    not specified
    Jun 2005
    Edinburgh, UK
    47
    Don't think so.. am running LT that don't do lisp.
  8. #8
    AutoCAD 2007
    Mar 2004
    Homer Glen, IL
    350
    Co-worker playing a prank? That's always a possibility.
    AutoCAD 2005
    ADT 2005
