geussb Posted November 21, 2012 Share Posted November 21, 2012 so do i dash it? or what am i supposed to do to it to make it correct? Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 21, 2012 Share Posted November 21, 2012 The two cages would have to be separated. The "key" that P-F had you insert into the footing would only be there if the pier was poured after the footing. Otherwise, if it were one monolithic pour there would be no reason to form the key in the first place. Additionally, to be correct, P-F should have had some rebar in the shape of an "L" coming up from the footing into the pier above to tie the two sections together when the pier was poured. But I guess they neglected to mention this as they must figure they are only trying to teach you AutoCAD not structural engineering. That's how they can get away with being "sloppy" in their project instructions. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 21, 2012 Share Posted November 21, 2012 Look at the second image on the right. It is for a monolithic pour (i.e. - no key). http://www.wirelessestimator.com/industryinfoselect.cfm?categid=136 Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 21, 2012 Share Posted November 21, 2012 An example of steel reinforcement that might be used for a footing and a pier. The two horizontal "mats" are comprised of #4 rebar 12" O.C. (on center) both ways. The four vertical bars bent in the shape of a letter "L" are hooks used to tie the footing to the pier. The hooked ends keep the bars from pulling out. The six square shapes with the rounded corners would be "bents". They tie the four hooks together and help to reinforce the pier. The question for you is how would you draw the top, front and side views of this in 2D? Note the position of the rebars that comprise each mat. Four bars sit atop the three going left and right. Quote Link to comment Share on other sites More sharing options...
ReMark Posted November 21, 2012 Share Posted November 21, 2012 One of the views in 3D. Ignore the object and the 'X' in the lower left corner (part of the UCS icon). Quote Link to comment Share on other sites More sharing options...
geussb Posted December 27, 2012 Share Posted December 27, 2012 now im on Section A (plate 3) in the structural project, i cannot visualize what it should look like. does anyone have a screenshot of what the sections should be showing? it says that the drain is going 1/8" for every 1' but are we now learning the roof is sloped or something? i dont get it Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 27, 2012 Share Posted December 27, 2012 It says quite clearly on page 14 of the instructions "The roof is also made up of a steel deck system. The top of the concrete slab, however, slopes toward the roof drain at a rate of 1/8″ every 1′-0″." Considering you paid good money for this course I would contact one of the "professors" and request some clarification. Please note that although I am clearly being sarcastic it is not directed at you. The projects for the Penn-Foster AutoCAD course are so poorly put together anyone working in the particular fields of civil, structural. electrical, and HVAC would undoubtedly laugh. Quote Link to comment Share on other sites More sharing options...
