rmdz Posted February 25, 2009 Share Posted February 25, 2009 Greetings, I am developing a small application with AutoCAD VBA +, which consists of: click to insert a block, then insert another block and between the two blocks to generate a line and continue inserting blocks I need is to generate a shortcut menu via RIGHT BUTTON to change the block or terminate the process, for example a drawing of Annex, I try to do what someone could give me a guide or code for generating the process Excuse my bad English Thanks in advance for the help Quote Link to comment Share on other sites More sharing options...
