+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
  1. #1
    kitewader
    Default Now desperate for dimension extraction help
    Can anyone please help. We are looking for a LISP routine that will list the dimensions of lines of the selection to a simple list that we can import into excel. My knowledge of LISP is not quite as advanced as zero, but I know this can be done and it would save me hours.
    Anyone, please……………
  2. #2
    Super Moderator fuccaro's Avatar
    Using
    AutoCAD 2006
    Join Date
    Nov 2002
    Location
    Romania, Marosvasarhely
    Posts
    3,540
    Default
    Something like THIS one?
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
  3. #3
    kitewader
    Default
    fuccaro, you are a giant amongst men. That's superb - in fact all we need is the length. The start,end, centres etc are superfluous but we can just delete those columns in the spreadsheet.
    Thanks again!
  4. #4
    Using
    AutoCAD 2006
    Join Date
    Nov 2002
    Location
    Posts
    3,540
    Default
    Quote Originally Posted by kitewader
    ... all we need is the length. The start,end, centres etc are superfluous but we can just delete those columns in the spreadsheet.
    ... or adjust the lisp code to export only what you need.
  5. #5
    kitewader
    Default
    Easy for you to say, as a complete novice in LISP it's easier to delete the excel data. I did try to alter the code but just got nowhere.
    Thanks for your help and suggestions again.
    Of course, if you were bored one day and wanted something to do.........
  6. #6
    Using
    AutoCAD 2006
    Join Date
    Nov 2002
    Location
    Posts
    3,540
    Default
    Code:
    ;|    Program to export line lengths into a CSV file
       mfuccaro@hotmail.com
    ---------------------------June 2005
    (defun c:LL2F( / name file ss ssi enl)
      (setq name (getvar "dwgname")
      	file (open (getfiled "Output file..." name "CSV" 1) "w")
    	ss (ssget) ssi -1)
      (if ss
          (repeat (sslength ss)
    	(setq enl (entget (ssname ss (setq ssi (1+ ssi)))))
    	(if (= "LINE" (cdr (assoc 0 enl)))
    	  (write-line (rtos (distance
    			      (cdr (assoc 10 enl))
    			      (cdr (assoc 11 enl)))) file)))))
      (close file)
  7. #7
    kitewader
    Default
    Thanks for that. When I try to load it it gives an error command of:
    ; error: bad character read (octal): 0
    Is it operator error (me) of a glitch in the code??
  8. #8
    Using
    AutoCAD 2006
    Join Date
    Nov 2002
    Location
    Posts
    3,540
    Default
    I gived it a quick try and it worked for me. Please try again and return here with a new message. I will see tomorrow what can I do.
  9. #9
    kitewader
    Default
    Hi,
    No, still getting the same error.
    Here’s what I’ve done.
    Pasted the code into wordpad, saved it as ll2f.lsp
    I get a “ll2f.lsp successfully loaded message” in the Load/Unload Applications Dialogue Box.
    The command line then shows:
    Command: _appload ll2f.lsp successfully loaded.
    Command: ; error: bad character read (octal): 0
    If I enter “ll2f” in the command line it gives:
    Unknown command "LL2F". Press F1 for help.
    The other (lst.lsp) LISP loads and runs fine.
    I appreciate your help.
  10. #10
    Using
    AutoCAD 2006
    Join Date
    Nov 2002
    Location
    Posts
    3,540
    Default
    Well, this time I am out of ideas. Maybe try to use Notepad instead of Wordpad
Posting Permissions
  • You may not post replies
  • You may not edit your posts
