Results 1 to 3 of 3
    Junior Member
    AutoCAD 2007
    Sep 2007
    23
    Default print jpg in scale from layout
    Hi guys,
    I have noticed that whenever I print a jpg or a png from layout and I want it to be in the right scale I choose Autocad always prints it out of scale. What's the problem?
    I normally use the zoom xp factor (1000/scale req xp) and sometimes even this doesn't work, even if I take into account the mm to m or cm factor between paper space and model space.
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,786
    Are you re printing the jpg ? then you will probably have a problem with scale.
    Its to do with the dpi setting and the size of your sheet etc I played around with tiffout for our company and you have to work out your sheet size in DPI if you want to replot it at 1:1 scale same problem with pdf's. The guys here have just about given up re-plotting them back to correct scale.
    Senior Member AlinOz's Avatar
    AlinOz's Computer Details
    Windows 7 64 bit
    HP xw4600
    6GB
    AutoCAD 2011
    Feb 2009
    Brisbane, Australia
    149
    OK, have you tried to scale the JPG up in Modelspace? Ive quite often scaled up a graphic file and it will work fine. I've quite often been given PDF files that have insufficient information and have needed to trace it to get it close. Here are the steps I've taken to get it (you may just need the scale side of this)
    1. Open the PDF in the Viewer and zoom up to the area I need to trace
    2. Use the CTRL 'Print SCRN' to copy the display to the Clipboard
    3. Paste it into AutoCAD - In your case you start here by inserting the graphic
    4. Use the Scale command and select the Graphic (note: you will need to have the border of the graphic showing with IMAGEFRAME set to either 1 or 2 as required)
    5. Within the scale command, Pick a basepoint then type 'R' (for Reference), Pick another reference point then type in the length you want the distance between those points to be.
    That will scale it up to the right size!!! Does that help?
    Last edited by AlinOz; 3rd Mar 2009 at 11:26 pm. Reason: Oops - I hit the Tab and it submitted it
  1. Print Task Quick Set - associate with layout?
    By fostertom in forum AutoCAD Drawing Management & Output
    Last Post: 11th Apr 2008, 05:16 pm
  2. building layout to print smaller
    By JessicaDeaken in forum AutoCAD Beginners' Area
    Last Post: 18th Jan 2008, 02:54 am
  3. How to print a scale square?
    By Almaz in forum AutoCAD Beginners' Area
    Last Post: 16th Sep 2007, 09:10 am
  4. Print Rendered Layout ?
    By Brunello19 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Dec 2005, 09:12 am
  5. scale in print
    By cadbaby in forum AutoCAD General
    Last Post: 19th Feb 2005, 06:22 am
