Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Senior Member
    Civil 3D 2008
    Feb 2008
    294
    Default Angle/Slope of Tangent to a curve vb.net
    Is anyone able to help
    In vb.net how do i find the angle of the tangent line to a curve at a given point relative to the X axis?
    Also would this have to be quadrant sensitive?
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    Don't know vb.net, but the function/expression you need is the "arc tangent", so look for something like that. In lisp it's "atan". And yes it's quadrant sensitive, positive tangent would give you a 0-90 degree result, negative is for a 90-180 degrees.
    **edit** found this, might help:
    This example uses the Atan method of the Math class to calculate the value of pi.
    Code:
    Public Function GetPi() As Double
        ' Calculate the value of pi.
        Return 4.0 * Math.Atan(1.0)
    End Function
    Super Member SEANT's Avatar
    AutoCAD 2012
    Aug 2005
    Rhode Island
    1,971
    The general methodology for 3d curves would be:
    1. Select the curve
    2. Pick a point(Point3d) on the curve with (DatabaseServices.Curve.GetClosestPointTo)
    3. Get first derivative(Geometry.Vector3d) with(DatabaseServices.Curve.GetFirstDerivative (Geometry.Point3d))
    4. Get angle with System.Math.Atan(Geometry.Vector3d.Y/Geometry.Vector3d.X)
    Senior Member
    Civil 3D 2008
    Feb 2008
    294
    ahh thank you very much
  5. #5
    Senior Member
    Civil 3D 2008
    Feb 2008
    294
    so how do i calculate what quadrant it is in so that i can calculate the 'Normal to the tangent'.?
  6. #6
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,818
    Tan is positive for quadrants 1 and 3 and negative for quadrants 2 and 4, hence a positive result indicates a vector at 0-pi/2 to the x-axis, plus or minus pi; and negative pi/2 - pi, plus or minus pi.
    I suppose you could add coding to correct the angle by pi radians so that you will only get an answer between 0 and pi, then the normal to the tangent will just be the arctan + pi/2.
    Is this a purely 2D problem, or are you interested in the Binormal to the tangent also?
    Lee Mac Programming
    Just another Swamper
  7. #7
    Senior Member
    Civil 3D 2008
    Feb 2008
    294
    No its purely 2d.
    Thanks for that - i changed the code around so it will work now.
    This is what i have.
    Code:
    Public Function CalcAngle(ByVal ObjCurve As AcadNetDbServices.Curve, ByVal Dist As Double)
    Dim Radians As Double
    Dim Degrees As Double
    Dim Point1 As AcadNetGeometry.Point3d = ObjCurve.GetPointAtDist(Dist)
    Dim firstderiv As AcadNetGeometry.Vector3d = ObjCurve.GetFirstDerivative(Point1)
    Radians = Math.Atan2(Cdbl(firstderiv.Y) , Cdbl(firstderiv.X))
    Degrees = Radians * (180 / Math.PI)
    'If in positive quadrants then = 180 - abs.Degrees
    'If in Negative quadrants then = Abs.Degrees - 180
    If Degrees < 0 Then
    Degrees = (Math.Abs(Degrees)) + 180
    Else
    Degrees = 180 - (Math.Abs(Degrees))
    End If
    CalcAngle = Degrees
    End Function
  8. #8
    Forum Deity
    not specified
    Jul 2004
    Anchorage, Alaska
    2,074
    Not sure why you would set Degrees = 180 - angle for any positive result. Say it was initially calculated at 45 degrees, wouldn't that be a good answer already? But then I don't know what you're using it for...
  9. #9
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,818
    I don't know much about vb.net (in fact I know absolutely nothing about it), but when you find the first derivative, does that not return a vector? - Then you would know exactly the direction of the tangent from the vector.
    Lee Mac Programming
  10. #10
    Senior Member
    Civil 3D 2008
    Feb 2008
    294
    derivative gives the slope of the tangent.
    using atan2 gets the arc tangent to it.
    also i had to use Degrees = 180 - Angle in the positive quadrant because i was getting answers like 175 & 115 when it should be 5 & 65 etc
    Thanks for your help guys.
    This works
  1. how do you shade 20% slope
    By paulg in forum AutoCAD General
    Last Post: 21st Jan 2010, 09:00 pm
  2. Slope of a line
    By smorales02 in forum AutoCAD General
    Last Post: 13th Aug 2008, 03:50 pm
  3. Top, bottom of Slope linetype
    By Hardney in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 16th Jun 2008, 01:01 pm
  4. Slope Shading Questions
    By ebwbjen in forum AutoCAD Drawing Management & Output
    Last Post: 31st May 2008, 11:46 pm
  5. Tangent,Tangent,Radius?
    By bugleboy62 in forum AutoCAD Beginners' Area
    Last Post: 10th Feb 2007, 09:57 am
