Results 1 to 10 of 10
    Forum Newbie
    AutoCAD 2008
    Feb 2009
    5
    Default Small rectangle difficulties :(
    Hi everyone,
    I just started AutoCAD for a few days, and I am getting stuck with one small exercise (regarding rectangle):
    I really dunno how to make it only with rectangle ???? Even if I tried using Fillet, it made the same fillet at the 4 corner
    Thanks ...
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    Quote Originally Posted by hostmax View Post
    The Fillet command can be used on a whole polyline (rectangle), or just in separate corners. If you select a (few) corner(s) for filletting, it will fillet only the selected one(s).
    But I think you menat the CHAMFER command.
    Welcome in the forum, Hostmax!
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    Forum Newbie
    AutoCAD 2008
    Feb 2009
    5
    Thanks for your reply ...
    I'm sorry for misleading you, but I mean Chamfers option when I use Rectangle tool , not the Chamfers tool (as I am only allowed to use Rectangle in this exercise)
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,965
    When you start the RECTANGLE command, if you read the command line, the first option is to set up the chamfers. So then you can set those to 45, and then draw the large rectangle, which will be drawn with the chamfers. Then start the Rectangle command again, but make the chamfers 0, then you can draw the four smaller rectangles.
    READ THE COMMAND LINE
  5. #5
    Full Member
    AutoCAD 2007
    May 2008
    54
    hi there...
    try this to control the size of the rectangle..
    1. command >rec (or clik icon)
    2. select a point
    3. type > d (for distance)
    4. type > 70 (x dist)
    5. type > 50 (y dist)
    6. clik anywhere to accept
    peace out
  6. #6
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,965
    Quote Originally Posted by kool130 View Post
    hi there...
    2. select a point
    Or like this
    1a. type > c (for chamfer distances, and set them to 45)
    2. select a point
    4. type > 160 (x dist)
    5. type > 105 (y dist)
    Then you could draw the smaller rectangles without changing the chamfers, because the sides of the small rectangles are not long enough for the chamfers to be drawn.
  7. #7
    Full Member
    AutoCAD 2007
    May 2008
    54
    yehhh eldon...bulls eye!!!
  8. #8
    Forum Newbie
    AutoCAD 2008
    Feb 2009
    5
    Quote Originally Posted by eldon View Post
    Thanks for ur reply,
    The prob is that, the biggest rectangle in the center (which has chamfers) has 4 chamfers, but 4 chamfers do not have the same dimension How can I make 2 different-size chamfers with exact dimension only with rectangle tool ??? ('cause I can not use Line to scale them)
  9. #9
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,965
    O.K. What size are they? The diagram does not seem to give all the information, and by looking at it, the chamfers look the same, and quite often in the real world, are the same.
  10. #10
    Forum Newbie
    AutoCAD 2008
    Feb 2009
    5
    If thats the case ... then its solved Thx a lot !! Our forum is really great
  1. XRef Difficulties
    By billyreiter in forum AutoCAD General
    Last Post: 15th Dec 2008, 10:46 pm
  2. Number Array Difficulties - Probably Just a Simple Mistake...
    By Lee Mac in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th Oct 2008, 02:13 pm
  3. rectangle basics
    By deansdream in forum AutoCAD Beginners' Area
    Last Post: 28th May 2008, 12:21 pm
  4. Rectangle
    By Chuck Stewart in forum AutoCAD General
    Last Post: 5th May 2007, 05:39 pm
  5. New install creating mouse difficulties
    By Lee in forum AutoCAD Drawing Management & Output
    Last Post: 18th Oct 2005, 01:37 pm
