This may do it, but not sure what point it scales around when you select by window, or multiple picks (last pick?).
Code:*^C^C_select;\_scale;_p;;@;0.786885245;
I currently use this code to scale things (have different buttons for different scales) It scales select object at the point it was selected. I want to be able to choose multiple objects and the point at which to scale (as you can see the number im scaling by is not one that i want to have to type in every time which is why just the scale command will take forever I have a lot of roomnames and number to scale from 11 7/16" text to 9" text usually these are done with blocks and my code works for that just not when you need to select multiple things to scale around a specific point) any help would be great... the code i use now is below
Code:*^C^C_scale \ @ .786885245;
"The problem is stupidity. I am not saying there should be capital punishment for stupidity, but, why don't we just take the safety labels off of everything and let the problem solve itself? "
I'm not sure I understand... Are you trying to scale blocks each at their own insertion point?
Last edited by uddfl; 3rd Mar 2009 at 07:53 pm. Reason: Code deleted - not applicable to thread question
"AS IS" AND WITH ALL FAULTS.
works great. i used a window to select and it scaled from the first point of the window
they arent blocks and that was my problem, usually they are a block for our roomnames but not this time. my code scaled them from the point i picked but since they arent blocks that didnt work because they needed to retain approximate spacing from other info, but carlB's code worked great
