Grigs Posted March 3, 2009 Share Posted March 3, 2009 I'm looking for a program or Excel spreadsheet or something that will allow me to enter the components of a wall and calculate the R values. Does anyone know of a program/spreadsheet that will do this? Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 4, 2009 Share Posted March 4, 2009 Is this what you are referring to? http://www.ornl.gov/sci/roofs+walls/whole_wall/ Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 4, 2009 Share Posted March 4, 2009 Calculating heat loss using "R", "U" and "K" values. http://www.inspect-ny.com/interiors/Heat-Loss-Calculation.htm Quote Link to comment Share on other sites More sharing options...
Grigs Posted March 4, 2009 Author Share Posted March 4, 2009 Kinda. What I was looking for was something that I could enter the components of a wall and it would tell me the R value of each item plus a running total. So if, for example, I had a 8" concrete wall that was furred with 2x4 wood studs filled with batt insulation and 5/8" gyp. board it would would show the R values of each component and then a total for the wall. Quote Link to comment Share on other sites More sharing options...
ReMark Posted March 4, 2009 Share Posted March 4, 2009 Then what you should be looking for is a R-value calculator. This link might provide what you're looking for. http://www.ornl.gov/sci/roofs+walls/AWT/InteractiveCalculators/rvalueinfo.htm Quote Link to comment Share on other sites More sharing options...
