Purge Audit Save
skipsophrenic
Hi all,
The macro that was on my machine at work is a bit "buggy" so I was
hoping to write a lisp to do the same thing, I've used ASMI's code
from THIS post as a starting guide, but could someone just run over
my code and tell me if there are any problems they spot pls.
;;;(Purge->Audit->Save)
(defun c:pas ()
 (vl-load-com)
 (repeat 3
   (vla-PurgeAll
     (vla-get-ActiveDocument
(vlax-get-acad-object)
 )     ; end repeat
 (command "_.qsave")
 (command "_.Audit" "y" "")
)     ; end of c:pas
This should work on anything newer than R14. -David
[b][color=BLACK]([/color][/b]defun c:pas [b][color=FUCHSIA]([/color][/b][b][color=FUCHSIA])[/color][/b]
  [b][color=FUCHSIA]([/color][/b]command [color=#2f4f4f]"_.ZOOM"[/color] [color=#2f4f4f]"_C"[/color] [color=#2f4f4f]""[/color] [color=#2f4f4f]""[/color][b][color=FUCHSIA])[/color][/b]
  [b][color=FUCHSIA]([/color][/b]while [b][color=NAVY]([/color][/b]> [b][color=MAROON]([/color][/b]getvar [color=#2f4f4f]"DBMOD"[/color][b][color=MAROON])[/color][/b] 0[b][color=NAVY])[/color][/b]
         [b][color=NAVY]([/color][/b]command [color=#2f4f4f]"_.QSAVE"[/color]
                  [color=#2f4f4f]"_.PURGE"[/color] [color=#2f4f4f]"_All"[/color] [color=#2f4f4f]"*"[/color] [color=#2f4f4f]"_No"[/color][b][color=NAVY])[/color][/b][b][color=FUCHSIA])[/color][/b]
  [b][color=FUCHSIA]([/color][/b]command [color=#2f4f4f]"_.AUDIT"[/color] [color=#2f4f4f]"_Yes"[/color][b][color=FUCHSIA])[/color][/b]
  [b][color=FUCHSIA]([/color][/b]command [color=#2f4f4f]"_.QSAVE"[/color][b][color=FUCHSIA])[/color][/b]
  [b][color=FUCHSIA]([/color][/b]prin1[b][color=FUCHSIA])[/color][/b][b][color=BLACK])[/color][/b]
Make sure you have backups 'cause there is no turning back after you run it. -David
