Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
    Senior Member
    AutoCAD 2007
    Apr 2008
    258
    Default Convert Mline To Pline
    Is There Any Way Convert Multiline To Polylines?
    Junior Member
    AutoCAD 2008
    Jun 2008
    14
    I don't know how to do it directly, but you can always use EXPLODE. Then select a segment and use PEDIT. It asks if you want to convert to a pline. Say "yes" the use JOIN to get all the pieces back together.
    Should work, but does anyone have a more direct way that could eliminate the need to select each segment individually?
    --DM
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,454
    Perhaps :
    Code:
    (defun c:m2p (/ vlst ovar ent ss elast)
      (setq vlst '("CMDECHO" "PEDITACCEPT")
        ovar (mapcar 'getvar vlst))
      (if (and (setq ent (car (entsel "\nSelect Multi-Line...")))
           (eq "MLINE" (cdadr (entget ent))))
          (mapcar 'setvar vlst '(0 1))
          (command "_explode" ent) (setq ss (ssadd))
          (mapcar '(lambda (x) (ssadd x ss)) (Ent_List_to_End ent))
          (setq elast (entlast))
          (command "_pedit" "_M" ent ss elast "" "_J" "" ""))
        (princ "\n<!> No Multi-Line Selected <!>"))
      (mapcar 'setvar vlst ovar)
      (princ))
    (defun Ent_List_to_End(ent / a)
      (reverse
        (if(setq a(entnext ent))
           (cons ent(Ent_List_to_End a)))))
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Senior Member
    AutoCAD 2007
    Apr 2008
    258
    Thanks Lee Mac For Your Help As I Expect From You ALWAYS
    And Thank You Also Drainmasta Really I Want Lisp Routine To Do That And Lee Mac Make It
    Thanks Again Guys For Your Help
  5. #5
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,454
    No probs, happy to help Mr Man
  6. #6
    Junior Member
    AutoCAD 2008
    Dec 2009
    17
    Default lee mac great man
    u r a great man lee thank u thank u thank u for this code it is too useful..
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,454
    Quote Originally Posted by aryanarch View Post
    You're welcome
  8. #8
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    19,454
    This is probably better:
    Code:
    (defun c:m2p (/ *error* EntNext_to_End DOC ELST ENT I MSS OV SS UFLAG VL)
      ;; MLine to PLine  ~  Lee Mac  ~  04.01.10
      (defun *error* (msg)
        (and ov    (mapcar (function setvar) vl ov))
        (and uflag (vla-EndUndoMark doc))
            (princ (strcat "\n** Error: " msg " **")))
        (princ))
      (defun EntNext_to_End (ent / a)
        (if (setq ent (entnext ent))
          (cons ent (EntNext_to_End ent))))
      (setq vl '("CMDECHO" "PEDITACCEPT" "QAFLAGS")
            ov  (mapcar (function getvar) vl) ss (ssadd))
      (mapcar (function setvar) vl '(0 1 0))
      (if (setq i -1 mss (ssget "_:L" '((0 . "MLINE"))))
          (setq uFlag (not (vla-StartUndoMark
                             (setq doc (vla-get-ActiveDocument
                                         (vlax-get-acad-object))))))
          (while (setq ent (ssname mss (setq i (1+ i))))
            (setq eLst (entlast) ss (ssadd))
            (vl-cmdf "_.explode" ent)
            (mapcar (function (lambda (x) (ssadd x ss)))
                    (EntNext_to_End eLst))
            (vl-cmdf "_.pedit" "_M" ss "" "_J" "" "")
            (setq ss nil))
          (setq uFlag (vla-EndUndoMark doc))))
      (princ))
  9. #9
    Forum Newbie
    Land Desktop 2009
    Oct 2010
    6
    Hey Lee, I was wondering if you could help me out too. I'm looking for a similar lisp to the one you wrote but with a little extra. I tried to combine yours with another lisp I found and had some success but I still can't figure out how to finish it off. I'm trying to draw an Mline, have it explode and made into a polyline, and then put the polylines created on 2 or 3 specific layers. I'm up to the point where I have your lisp make the polylines and they end up on a single layer that was made current at some point in the lisp, but I can't figure out how to select certain lines to bring to a new current layer. or something like that.
  10. #10
    Forum Newbie
    Land Desktop 2009
    Oct 2010
    6
    Here's your edited code I was working with:
    Code:
    (defun c:mlb ( / *error* vl ov LastEntity ent ss currlay)
      ;; © Lee Mac  ~  19.06.10
    (setq currlay (getvar "clayer"))
    (SETQ lr1 (TBLSEARCH "LAYER" "P-SD-CL-L"))
    (IF (= LR1 NIL)
    (COMMAND "LAYER" "MAKE" "P-SD-CL-L" "COLOR" "BYLAYER" "" ""))
    (command "layer" "set" "P-SD-CL-L" "" "")
        ;;Sco'S COMMENTS - SETS LAYER FOR NEW OBJECTS, IF MISSING, CREATES IT.
      (defun *error* ( msg )
        (mapcar 'setvar vl ov)
        (princ))
            ov (mapcar 'getvar vl))
      (setq LastEntity (entlast))
      (command "_.mline" "ST" "B")
      (while (= 1 (logand 1 (getvar 'CMDACTIVE)))
        (command pause))
        (prompt "pick")
      (if (not (equal LastEntity (setq ent (entlast))))
          (mapcar 'setvar vl '(0 1 5))
          (vl-cmdf "_.explode" ent "")
          (setq ss (ssadd))
          (mapcar '(lambda ( e ) (ssadd e ss)) (LM:EntnexttoEnd ent))
          (vl-cmdf "_.pedit" "_M" ss "" "_J" "" "")))
    (I hope I didn't mess it up too bad)
    So I'm using a 3 line Mline with one in the center and 2 offset .5 either side. I have all brought on to the P-SD-CL-L layer. At the end I was want to select the 2 outer lines and bring them onto a new layer (P-SD-L), but leave the center on P-SD-CL-L. I kept trying to change current layer again and then select 2 previous but I just couldn't figure it out.
    Any help would be greatly appreciated.
  1. Can I convert an oval to a pline?
    By pico in forum AutoCAD Drawing Management & Output
    Last Post: 6th Jun 2007, 03:28 am
  2. Why can't I convert this to one single pline?
    By CADIDAC in forum AutoCAD 3D Modelling & Rendering
    Last Post: 27th Feb 2007, 03:11 pm
  3. mline
    By comcu in forum AutoCAD Drawing Management & Output
    Last Post: 26th Jan 2007, 03:08 pm
  4. convert spline to pline
    By wanni in forum AutoCAD Beginners' Area
    Last Post: 10th Nov 2005, 04:04 am
  5. Convert Spline to Pline
    By f700es in forum AutoCAD Drawing Management & Output
    Last Post: 19th Feb 2004, 01:31 pm
