Results 1 to 2 of 2
    Forum Newbie
    AutoCAD 2005
    Mar 2009
    1
    Default Multi-Line Dimensions
    Hi Folks,
    Newbie here to the forum!
    Can anyone on here tell me how i can create a dimension with 2 lines of text?
    something along the lines of ...
    25mm TO CENTRE
    OF FIXING HOLES
    Is there an easy way to do this using text override or can this be done another way?
    Cheers!
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,402
    text override <>TO CENTRE \XOF FIXING HOLES
    if needing all above dim line
    <> TO CENTRE \N OF FIXING HOLES
    OR in dim style, suffix
    \X TO CENTRE OF FIXING HOLES
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  1. Convert Single line text to multi-line?
    By LKJR in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 16th Jan 2013, 07:31 pm
  2. multi line problems
    By comcu in forum AutoLISP, Visual LISP & DCL
    Last Post: 11th Sep 2008, 10:50 pm
  3. Multi-Line Text
    By trin_rob in forum AutoCAD Drawing Management & Output
    Last Post: 13th Jul 2007, 04:38 pm
  4. Multi-line text spacing
    By edwin in forum AutoCAD Drawing Management & Output
    Last Post: 11th Dec 2006, 06:00 am
  5. multi line
    By Dean07 in forum AutoCAD Drawing Management & Output
    Last Post: 13th Jun 2006, 06:30 am
