Results 1 to 7 of 7
    Full Member
    AutoCAD 2008
    Jan 2009
    31
    Default The simplest things seem to get me stuck..
    I have a list, and I am trying to loop trough the list, change each string in the list and add the new string to a new list. I cant get the result to the bottom or the top of the list. It seems like whatever I try it creates a 2 item list, the first item is the last edited string, and the last item is a string of every other previously altered string. How do I get it to put a new line on the string? I have tried append, multiple variations of cons and everything else I can find. I know this is really simple but for some reason, I seem to get hung up on the easy things.
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,708
    Not sure exactly what you are trying to do (a piece of sample code would help), but I would just use "cons" to put the new string in a list:
    Code:
    (setq strlst (cons *newstring* strlst))
    Lee Mac Programming
    Just another Swamper
    Full Member
    AutoCAD 2008
    Jan 2009
    31
    Thanks for the help Lee.
    I had been trying this and all sorts of variations with CONS but it still isnt creating my list in the desired format.
    Here is a sample
    (setq user (dos_username))
    (cond ((= user "BLockhart")
    (setq userp "Ben"))
    ((= user "CBearden")
    (setq userp "Chris"))
    ((= user "LBrown")
    (setq userp "Lavon"))
    ((= user "RChambers")
    (setq userp "Ronnie"))
    ((= user "JMitchell")
    (setq userp "Justin"))
    ((= user "JPrice")
    (setq userp "Joe"))
    ((= user "LCooper")
    (setq userp "Lonny"))
    (setq userp (getstring "\n Please enter your first name: "))
    );cond end
    (setq maindir (dos_getdir "Select directory you wish to print:" (strcat "W:\\"userp"\\New Projects")))
    (setq sublist (dos_subdir maindir))
    (setq subnum (length sublist))
    (setq cnt 0)
    (setq dwglist "")
    (while (< cnt subnum)
    (setq fldr (nth cnt sublist))
    (setq dwglist (cons (strcat maindir fldr) dwglist))
    (setq cnt (+ cnt 1))
    This somewhat works, but my list comes out looking like this.
    LOG ("W:\\Ben\\New Projects\\Solvay\\test\\109487" "W:\\Ben\\New Projects\\Solvay\\test\\109478" "W:\\Ben\\New Projects\\Solvay\\test\\109476" "W:\\Ben\\New Projects\\Solvay\\test\\109455" "W:\\Ben\\New Projects\\Solvay\\test\\109452" "W:\\Ben\\New Project...
    [car] "W:\\Ben\\New Projects\\Solvay\\test\\109487"
    [cdr] ("W:\\Ben\\New Projects\\Solvay\\test\\109478" "W:\\Ben\\New Projects\\Solvay\\test\\109476" "W:\\Ben\\New Projects\\Solvay\\test\\109455" "W:\\Ben\\New Projects\\Solvay\\test\\109452" "W:\\Ben\\New Projects\\Solvay\\test\\109438" "W:\\Ben\\New Project...
    Like I said, I know there is something amazingly simple I am missing, but it's driving me batty
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,708
    I can't really test it because it uses those "dos" functions... but give this a shot:
    Code:
                 (setq userp "Ben"))
            ((= user "LBrown")
            ((= user "JPrice")
                 (setq userp "Joe"))
            ((= user "LCooper")
        );cond end
        (setq sublist (dos_subdir maindir) subnum (length sublist) cnt 0)
              (setq dwglist (cons (strcat maindir fldr) dwglist) cnt (+ cnt 1))
    Lee Mac Programming
  5. #5
    Super Member CAB's Avatar
    AutoCAD 2000
    May 2004
    Tampa, Florida
    801
    Another variation, untested.
    Code:
    (setq userp (cadr (assoc user
                            '(("BLockhart" "Ben")
                              ("CBearden"  "Chris")
                              ("LBrown"    "Lavon")
                              ("RChambers" "Ronnie")
                              ("JMitchell" "Justin")
                              ("JPrice"    "Joe")
                              ("LCooper"   "Lonny")
    (if (null userp)
    (if
      (and
        (/= userp "")
                                  (strcat "W:\\" userp "\\New Projects")))
        (setq cnt -1)
       (while (< (setq cnt (+ cnt 1)) subnum)
  6. #6
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,708
    Ahh nice one CAB, good use of associative lists - I should have looked at this one a bit more.
    Lee Mac Programming
  7. #7
    Full Member
    AutoCAD 2008
    Jan 2009
    31
    Thanks for the help guys,
    This is what I finally got to work.
    (setq dwglist (append dwglist (list (strcat maindir fldr))))
    Everything else made my list look funny. and I was dreading having to pull info from it.
    In case you're curious, I am working on a Batchplot lisp that searches a directory for files that match a certain criteria, writes a script with the info and plots all of them.
    So basically, all the user has to do to plot off a job, is select a directory with all the part folders in it and it goes through the folders and pulls out the relevant files, (ignoring files used for xrefs and reference drawings) and plots them based on Border size. Let you know how it comes along....
  1. Replies: 8
    Last Post: 22nd Dec 2008, 01:42 pm
  2. Everything is stuck
    By NUBBZ143 in forum Autodesk Inventor
    Last Post: 26th Oct 2008, 03:44 am
  3. Capitals Stuck
    By DODGE in forum AutoCAD General
    Last Post: 15th Sep 2008, 01:08 am
  4. Viewport stuck on top
    By PEIBG in forum AutoCAD Drawing Management & Output
    Last Post: 29th Apr 2008, 07:52 pm
  5. Getting stuck in my layout tab :(
    By Rooster in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 25th Apr 2008, 01:23 pm
