Changes to plot layout and plot file for publish
GliderRider
File/publish is a great way to print when everything is set in the plot dialog box.
I have 11x17 and full size layouts in the layout tab.
Anyone have a way to quickly change the plot style in all without going in to all the dwgs and resetting it?
Ditto the layout from 11x17 to full size?
You can import page setups in the publish dialog from other drawings. Just create some drawings with a few saved. When you highlight the files to publish in the dialog, use shift to select them all. When you set the page setup in the one they all inherit it.
