Page 2 of 2 FirstFirst 1 2
Results 11 to 18 of 18
Thread: zoom extents?
  1. #11
    Full Member Tallguy's Avatar
    Tallguy's Computer Details
    Win XP
    Piece of crap
    2Gb
    Map 3D 2008
    Mar 2009
    Hampshire, UK
    34
    Dave, think you might be right re: corruption, will try erase all & remove, see if that works.
    Z O is really useful, as is Z P (zoom previous), which as it suggests is like an UNDO for zooms, going back in sequence through your recent views.
    Watch this space...
    Last edited by Tallguy; 18th Jun 2009 at 01:54 pm. Reason: typo due stupid sausage fingers too big for the keyboard
  2. #12
    Win XP
    Piece of crap
    2Gb
    Map 3D 2008
    Mar 2009
    Hampshire, UK
    34
    Angry Must be corrupted...
    Quote Originally Posted by skipsophrenic View Post
    When you've zoomed to extents press CNTRL + A an does it select anything in the "blank" area of your drawing?
    Nope.
    Quote Originally Posted by wannabe View Post
    Any layers turned off?
    Turned 'em all on, went for a coffee whilst it loaded up most of the OS raster tile TIFs, came back, still no luck.
    Quote Originally Posted by lpseifert View Post
    While in the Model Tab try
    Erase > All > Remove > [select what you want to keep]
    Did that, still no luck.
    Quote Originally Posted by CADTutor View Post
    This is usually the result of a drawing object being flung way out in space. How can this happen? Well, usually it happens during the move command when the user innadvertently hits <enter> rather than picking for the second point. It's a nice little quirk that has been around since for ever.
    The trick is to find the offending object (or objects). Sometimes it's obvious but often it's not. First, make sure all layers are turned on and unlocked. Then start the ERASE command and select ALL. Then use implied windowing to remove the objects you want to keepfrom the selection. Complete the erase and then Zoom Extents again to check all is well.
    Knew this was a possibility, but when ZOOM OBJECT gave strange results I discounted rogue entities and am leaning towards corruption (though not as much as the Houses of Parliament , I hasten to add).
    I shall henceforth continue rebuilding a new dwg by querying in layers from the corrupt dwg. All I need now is a TARDIS and a self-cloning-machine and I'll finish my task by 5pm. Hark! Is that irony I hear?
    Thanks anyway for your help, I'll let you know if anything exciting happens to fix the error. Though I fear something is rotten in the state of Hampshire.
  3. #13
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    DELL 23" & SAMSUNG 21"
    Electro/Mech
    dbroada's Discipline Details
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,118
    have you tried the WBLOCK method Mark & I suggested yet? It was the tool of choice for this sort of thing in the last millenium.
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    Dave
  4. #14
    Win XP
    Piece of crap
    2Gb
    Map 3D 2008
    Mar 2009
    Hampshire, UK
    34
    I'm too far down the line of rebuilding the dwg by querying in layers from the corrupted one, so far all is well.
    Much of my data is in SHP format, and that seems to have also gone wonky, just as well I saved the display manager layers.
    I'll chalk that one up to experience, next time it happens (and no doubt there WILL be a next time) I'll try the wblock thing (though it takes so b####y long to switch on all the Ordnance Survey rasters, I might as well go home and come back in the morning).
    Cheers Dave, mucho appreciato as they say in Italy.
    "Last millennium" seems such a long time ago, when I were a lad all we had were 1s and 0s, and sometimes we didn't even have the 1s...
  5. #15
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,997
    Just a thought, but what order of coordinates are you working in? If you have coordinates with large numbers, when you ZOOM OBJECT or EXTENTS, does the window include 0,0 as one corner?
  6. #16
    Win XP
    Piece of crap
    2Gb
    Map 3D 2008
    Mar 2009
    Hampshire, UK
    34
    Ordnance Survey GB_ORD1-MOD 1936 in metres. Hundreds of thousands of metres. Metres everywhere, messing up the place, vomiting on the carpet.
    I don't think it's that, I'm sure I've blown a gasket somewhere on this dwg as it's got other painful symptoms. Maybe it's proven Fermat's last theorem and is doing a little dance inside.
    Time for a lie down and a snack, I think.
  7. #17
    Super Member chelsea1307's Avatar
    chelsea1307's Computer Details
    windows xp
    AutoCAD 2011
    Sep 2008
    Sacramento, Ca USA
    1,109
    is the object your selecting a block or xref? If it is have you checked to see if zoom extents works on the original? or does it go way out into space, if its a block or xref and the original is out in space when you select the block not to delete you also select the random out of place object.
    "The problem is stupidity. I am not saying there should be capital punishment for stupidity, but, why don't we just take the safety labels off of everything and let the problem solve itself? "
  8. #18
    Win XP
    Piece of crap
    2Gb
    Map 3D 2008
    Mar 2009
    Hampshire, UK
    34
    I don't really need to use blocks or xrefs in my work, all objects are simple entities. The only external data are SHP files and map rasters.
  1. Zoom, Extents
    By cadmench in forum AutoCAD Beginners' Area
    Last Post: 18th Jun 2009, 01:33 pm
  2. Zoom extents
    By Aegis1 in forum AutoCAD General
    Last Post: 8th Aug 2008, 03:41 pm
  3. zoom extents
    By richjamesw in forum AutoCAD Drawing Management & Output
    Last Post: 17th Aug 2007, 01:34 pm
  4. Zoom Extents
    By Eche1on in forum AutoCAD Drawing Management & Output
    Last Post: 15th Sep 2006, 07:18 pm
  5. Where have my Zoom Extents gone?
    By JULES in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Mar 2006, 05:51 pm
