Senor Dorado Posted March 12, 2009 Share Posted March 12, 2009 I am having a problem with basic fundamentals while using AutoCad 2007. My problem is when creating a new dwg. I can not draw a line by initiating the line command picking a starting point and then move the pointer in the required direction and then entering the required length of the line. Is this a problem caused by using the default template acad.dwt or am I forgetting to change a setting when creating a new dwg. ? Please Help Senor Dorado Quote Link to comment Share on other sites More sharing options...
rkent Posted March 12, 2009 Share Posted March 12, 2009 More detail is needed on what problem you are seeing? Is the line not ortho, the distance entered isn't accepted, etc.? First guess is you are entering a distance in feet and inches but your UNITS are set to decimal. Hit escape a few times and type UNITS at the command line and pick architectural, now try line again. If non-ortho line is the problem either pick the ortho or polar button at the very bottom of the screen. Quote Link to comment Share on other sites More sharing options...
Senor Dorado Posted March 13, 2009 Author Share Posted March 13, 2009 Bingo! I'm a happy camper now, thanks for your timely reply. Senor Dorado Quote Link to comment Share on other sites More sharing options...
