Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Forum Newbie
    AutoCAD 2008
    Mar 2009
    7
    Default trim extend 3d objects
    can i use trim or extend command for 3dobject making
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    You can change the size of a 3D solid using the 3D editting commands such as Slice, Move Faces and Offset Faces. For your particular situation I would recommend the Move Faces command. However, without seeing the object you are working on consider my best guess.
    Forum Newbie
    AutoCAD 2008
    Mar 2009
    7
    i know that. but can we use the "trim" command for it
    Forum Newbie
    AutoCAD 2008
    Mar 2009
    7
    do you the 'audit' in file -> drawing utility-> audit menu
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    Trim and extend will not work on a 3D solid.
    What's up with the audit question? Are you experiencing a problem with a drawing?
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    SOLIDEDIT
    Faces:
    Extrude
    Move
    Rotate
    Offset
    Taper
    Delete
    Copy
    Color
    Undo
    Edges:
    Copy
    Color
    Undo
    Bodies:
    Imprint
    Separate solids
    Shell
    Clean
    Undo
    No trim and no extend available.
    However, in the course of constructing the basic geometry of a solid then those two commands could obviously be used. But you know that already.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    Read this article about Errors in AutoCAD Drawings to learn more about the Audit command.
    http://www.icad.net.au/Verify/Audit/audit.htm
  8. #8
    Forum Newbie
    AutoCAD 2008
    Mar 2009
    7
    thanks alot, the other question is "how we can create a land using surface command(edge surf).what we need to drw that?
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,740
    "how to create a land using surface command (edgesurf)..."
    Are you talking about creating a 3D contour map? I think it could be done using the Spline command for the contours themselves. The contours would have to be located at 0 on the Z axis and then moved to their actual locations in the Z axis. Once the contours are in the correct location you would have to use a line to connect (make sure to use Osnaps) the endpoints of the edges of the contours keeping in mind that edgesurf requires a four-edged surface. I'd recommend setting surftab1 and surftab2 to something like 40 and 4 respectively. As long as you always select two adjacent contours along with two edges you can systematically sequence through all the contours, creating meshes, until you are done.
    One last suggestion. As the meshes are created move them to a separate layer that is turned off. This should make it easier to choose the next set of contours you're working with.
  10. #10
    Cad64's Computer Details
    Windows 7 Profesional x64
    XI Computers
    Asus P8Z77-V Pro
    24GB DDR3 @ 1333MHz
    SATAII 500GB 7200 RPM
    Multi-disciplinary
    Cad64's Discipline Details
    Freelance Digital Artist
    Multi-disciplinary
    3D model building, texturing and rendering. Photoshop Color Graphics.
    AutoCAD 2014
    Feb 2006
    Southern California
    10,246
    Sureshkumarks1, welcome to the forum.
    Please start a new thread for any unrelated questions. I have moved your last question to it's own thread HERE since it has nothing to do with your original question, or with 3D.
    CGSociety Portfolio: http://rdeweese.cgsociety.org/
    Facebook:
    https://www.facebook.com/rdeweese67/
    "Work Smart, Not Hard"
  1. Trim/Extend
    By CAD-e-Corner in forum AutoCAD RSS Feeds
    Last Post: 15th Mar 2013, 06:50 pm
  2. trim/extend polylines
    By tonybolony in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 6th May 2008, 09:09 am
  3. Settings under Extend & Trim
    By bleeargh in forum AutoCAD Beginners' Area
    Last Post: 20th Jan 2006, 07:11 pm
  4. trim/extend command????help
    By vikasm in forum AutoCAD Beginners' Area
    Last Post: 11th Oct 2005, 12:04 am
  5. not able to trim/extend
    By bstk in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Sep 2005, 01:20 pm
