criehle Posted March 16, 2009 Share Posted March 16, 2009 Is there an easy way to manipulate the draw order of all objects in a layer with out selected every object and then sending them to the front or back or is this the only way to display the draw order and keep it that way? Quote Link to comment Share on other sites More sharing options...
EMS_0525 Posted March 16, 2009 Share Posted March 16, 2009 I downloaded a lsp routine that sends all the objects of a layer to the back... i use it for hatching... i dont think there is something like what you describe. unless you isolate the layer then do what you want.... Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted March 16, 2009 Share Posted March 16, 2009 A LISP routine may help as EMS mentioned - something like this maybe: (written quickly & untested): (defun c:layback (/ ent ss) (if (setq ent (car (entsel "\nSelect Object on Layer to Send to Back..."))) (progn (setq ss (ssget "X" (list (cons 8 (cdr (assoc 8 (entget ent)))) (if (getvar "CTAB")(cons 410 (getvar "CTAB")) (cons 67 (- 1 (getvar "TILEMODE"))))))) (command "_draworder" ss "" "_Back")) (princ "\n<!> No Object Selected <!>")) (princ)) Quote Link to comment Share on other sites More sharing options...
dtkell Posted March 16, 2009 Share Posted March 16, 2009 Don't forget the Express tools command SSX. It allows you to select a layer by name (among other things, check command line). Then do draworder, when select objects, type P for previous and the layer from SSX is selected and can be manipulated. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted March 16, 2009 Share Posted March 16, 2009 Nice idea Dtkell, hadn't thought about Express tools. Quote Link to comment Share on other sites More sharing options...
alanjt Posted March 17, 2009 Share Posted March 17, 2009 tested just enough to make sure it works: (defun c:DO (/ #Choice #Entsel #Entget #Layer #ssget) (setvar "cmdecho" 0) (setvar "errno" 0) (initget 0 "Back Front") (setq #Choice (getkword "\nDraworder Option [back/Front] <Back>: ")) (progn (if (not #Choice) (setq #Choice "Back") ) ;_ if (while (and (not (eq (getvar "errno") 52 ) ;_ eq ) ;_ not (not #Entsel) ) ;_ and (setq #Entsel (entsel (strcat "\nSelect object on layer to move to " #Choice ": " ) ;_ strcat ) ;_ entsel ) ;_ setq (if #Entsel (progn (setq #Layer (cdr (assoc 8 (entget (car #Entsel))))) (setq #ssget (ssget "_x" (list (cons 410 (getvar "ctab")) (cons 8 #Layer) ) ;_ list ) ;_ ssget ) ;_ setq (vl-cmdf "_.draworder" #ssget "" #Choice) (prompt (strcat "\nAll " (rtos (sslength #ssget) 2 0) " object(s) on layer \"" #Layer "\" have been moved to " #Choice ) ;_ strcat ) ;_ prompt ) ;_ progn ) ;_ if ) ;_ while ) ;_ progn (princ) ) Quote Link to comment Share on other sites More sharing options...
Peter K Posted March 17, 2009 Share Posted March 17, 2009 Map 3D doesn't have the acad command QSELECT? The reason I ask is because I know that's one command that is very undervalued as well as underused in plain Autocad. Quote Link to comment Share on other sites More sharing options...
