Please help with Inventor simulation
maceng
Hello everyone,
I have used other CAD software but I am new to Inventor. I am using Inventor 2009 and trying to simulate the translational/rotational motion of a saw blade (with the teeth) on a bandsaw machine. Basically just to show it moving (illusion?). Is that possible? Any help is appreciated!
Thanks
Hello, I was able to create the joints (pulley-belt) and simulate it using the dynamic simulation. The next part which is really the problem I am facing is to show the teeth (currently not shown on the blade) moving in the direction of rotation. It could be in some of form of optical illusion where each blade tooth appear and disappear in a certain sequence. I cannot attach the zipped file here because its size exceeds the limit.
Thank you for your help.
P.S: I think you have answered my post at another forum as well.
  • 1 year later...
hey guy I'm new to this forum,and I want urgent help please!!
I need to make a dynamic simulation for pulley/timing belt assembly.
I tried using "cylinder on plane" joint type but i cannot make the correct selection. any1 knows how to? what I need to do is to make one pulley to drive the timing belt and the belt to drive the other pulley..
