Results 1 to 3 of 3
    Forum Newbie
    AutoCAD 2008
    Mar 2009
    2
    Default AutoCAD Calculator
    I am using AutoCAD Architecture 2008. When using the distance tool in the calculator to measure it doesn't display in feet and inches it displays in inches with a decimal. How do I change this? I know it use to do this in older versions, I never had to worry about it before. Please help. Thank you.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Try units command.
    Forum Newbie
    AutoCAD 2008
    Mar 2009
    2
    What do you mean by that? My units are set to Architectural. It's just the calculator that is answering in decimals. When I use the regular distance command it comes out in feet and inches.
  1. U - Value Calculator In Mep
    By S.P.I in forum MEP
    Last Post: 3rd Mar 2009, 05:04 pm
  2. Is there a ddedit CALCULATOR?
    By coombsie11 in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Oct 2008, 02:15 pm
  3. Glass Size Calculator
    By comcu in forum AutoLISP, Visual LISP & DCL
    Last Post: 31st Jul 2008, 12:01 am
  4. splice plate calculator
    By Impala62 in forum AutoCAD General
    Last Post: 28th May 2008, 01:23 pm
  5. C - Calculator
    By CAD Panacea in forum AutoCAD RSS Feeds
    Last Post: 11th Jan 2007, 05:24 am
