Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
Thread: Delete Layers
    Full Member
    MEP 2009
    Mar 2009
    37
    Default Delete Layers
    I cannot delete layers which I am not using. I opened new drawing and in Layer Properties Manager I have 21 layers showing that i am using them excluding layers "0" and "Defpoints". How can I delete them? I cannot Purge them.
    Thanks
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,074
    0 can't be deleted. Defpoints is kinda tricky, but its an AutoCAD created layer so it can't be messed with. The one way to get rid of Defpoints is to run the command line version of PURGE, obviously if the layer is not beings used.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
    Senior Member neekcotrack's Avatar
    MEP 2009
    May 2008
    Florida
    329
    Quote Originally Posted by StykFacE View Post
    You can also draw lines of what layers you want to get rid of and type laydel and it will delete everything on the layer and the layer its self. Becareful it will delete everything on the layer no matter what!!!!!!
    Full Member
    MEP 2009
    Mar 2009
    37
    I apologize for not being clear I am not trying to delete "0" and "Defpoint" layers but the 21 layers which autocad saying they are being used. How can they be used if I just open new drawing from the scratch and those layers showed up on the Layer Properties Manager. I tried purge it cleared all unused layers but it did not deleted 21 layers.
    thanks
  5. #5
    MEP 2009
    May 2008
    Florida
    329
    Quote Originally Posted by repelectric View Post
    thanks
    Try what I said and it should take care of the problem.
  6. #6
    HP Zbook
    Multi-disciplinary
    BIM Specialist
    Multi-disciplinary
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,074
    Probably some blocks that are referenced to certain layers. To really "clean out" a drawing I usually do a Ctrl+A and hit the Delete key. Then I run a purge. Oh and don't forget to delete/clear everything from Paperspace.
  7. #7
    Full Member
    MEP 2009
    Mar 2009
    37
    Quote Originally Posted by neekcotrack View Post
    At first it did not work I guess i was doing it wrong and actually it worked the way you said it thank you I appreciate.
  8. #8
    Full Member
    AutoCAD 2008
    Feb 2009
    78
    Try using the command "laydel". In the Command Line, type "N" for name and then select and delete the layer.
    A.Rees
  9. #9
    Senior Member harrison-matt's Avatar
    harrison-matt's Computer Details
    Windows 7
    Acer Aspire TimelineX
    Intel i3
    4GB
    Dual
    MEP 2012
    Jan 2010
    NOVA/DC
    113
    You could even do a "laywalk" to see what layers are being used on what objects, then do the above mentioned laydel with name to filter the selections and delete multiple layers at once.
  10. #10
    Junior Member Micaletti's Avatar
    MEP 2012
    Oct 2009
    13
    In the case of AutoCAD MEP, most of those apparently unused layers are referenced in the Display and Style Manager. There is a layer for "liner hidden" for example, in every view. To truely have a clean drawing without all those layers, and to be able to purge those layers, you need to go through the Display Manager and get rid of or merge most of those layers set asside for hidden lines. The stock AutoCAD MEP templates are really bloated in the Display Manager.
    Steven Micaletti
    Virtual Mechanical
    Design Build Software & Content For AutoCAD MEP
  1. layers won't delete
    By gib65 in forum AutoCAD Drawing Management & Output
    Last Post: 5th Apr 2016, 10:29 pm
  2. Delete Layers Off
    By MR MAN in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 30th Aug 2008, 07:43 am
  3. delete all layers
    By JONTHEPOPE in forum AutoLISP, Visual LISP & DCL
    Last Post: 25th Jun 2008, 01:07 am
  4. How do I delete Layers?
    By chee_dee in forum AutoCAD General
    Last Post: 7th Sep 2007, 02:43 pm
  5. DELETE LAYERS
    By BITDRAUGHTY in forum AutoCAD Beginners' Area
    Last Post: 2nd Dec 2005, 07:52 pm
