coeziv Posted March 24, 2009 Share Posted March 24, 2009 Hello, I am having problems trying to arrange the labels of the cogo points. I measured a road, and all the points I took in the field are now in Civil 3d as cogo points with 3 labels ( point number, elevation and code). I want to arrange the elevation label so that I can plot the road. Right now the labels are on top of each other. The only method I could find is to pull on the grip of each label, but it's taking me too long. If anyone has any ideeas please help me. Thank you in advance ! Quote Link to comment Share on other sites More sharing options...
rkmcswain Posted March 24, 2009 Share Posted March 24, 2009 If they all need to be adjusted the same distance and direction, then you can either modify the current point label style or create a new one. If each point has to be adjusted individually, then that's probably the only way to go. Quote Link to comment Share on other sites More sharing options...
coeziv Posted March 24, 2009 Author Share Posted March 24, 2009 If they all need to be adjusted the same distance and direction, then you can either modify the current point label style or create a new one. If each point has to be adjusted individually, then that's probably the only way to go. I just want to adjust the labels so that they are not on top of each other. Sorry for my english. Quote Link to comment Share on other sites More sharing options...
rustysilo Posted March 24, 2009 Share Posted March 24, 2009 Are your point #, elevation, and description on top of each other or do you have multiple points near one another in which the labels are overlapping? Quote Link to comment Share on other sites More sharing options...
coeziv Posted March 24, 2009 Author Share Posted March 24, 2009 Are your point #, elevation, and description on top of each other or do you have multiple points near one another in which the labels are overlapping? I have multiple points one near each other in wich the labels are overlapping. The number, elevation and description label of a single point look good. Quote Link to comment Share on other sites More sharing options...
rustysilo Posted March 24, 2009 Share Posted March 24, 2009 Ahh sorry my friend, but I don't believe there is any way around that bit of cleanup. You might adjust the size of the points and labels which may help a little, but not likely enough. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 25, 2009 Share Posted March 25, 2009 You may want to create a number of lable styles say Height X,Y it can make the viewing a bit simpler also play with your lable text ht. There is no simple way to lable multiple points that are near each other and be readable. Also set the diifernet values to different angles ht = 0 x,y= 45 z =90 can make it easier to read Quote Link to comment Share on other sites More sharing options...
