forgive a stupid question, are you sure they are Texts? not blocks or anything? have you tried converting them one by one? Can you do it with any other Text? HAv you restarted your AutoCAD? Restarted your computer?
Never had this problem before. Am trying to convert 2 texts to mtext (they're not already).says "conversion failed" or something similar (can't remember the exact error message). Normally works.
Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
at the moment in one's personal UCS.
Go to PLAN view instead. - Dadgad
Converting them one by one works. Converting them together does not. They're not blocks.
Are they very much non-similar? Although according to the Express tools help, that doesn't seem to affect the command..
is it just these two? Would it work with two other texts?
Is occurring to all text in the drawing.
I'm schtumped.... according to the Express Help, the file associated with the command is Leaderex.arx in C:\Program Files\AutoCAD 2008\Express - you could try to exchange that file for one from somone elses machine, where the TXT2MTXT works.
