autocad extrude angle issue
johnnyk
Hi,
Im having real problems attempting to extrude an irregularly angled shape along a conventional axis to create solidity (for walls) Any help would be much appreciated.
Thanks in advance.
I have enclosed a copy of the geometry in question.
Johnny
55 canopy mar23.zip
Your drawing has four layers: 0, ground, floor and street. It appears that the only geometry depicted is ground (white) and street (green). I really can't tell what you want to extrude and what you are using for the path of the extrusion. Just looks like a whole lot of triangles to me. Maybe you could elaborate a bit more?
Hi Thanks for answering,
I have moved on (slightly!)
I am now extruding all seperate triangles along their own wall width path, unfortunatly there is still an issue with meeting corners.
I have included a revised dwg.
Thanks
Johnny
55 canopy mar23.zip
I think I see what you are referring to. You want all the triangles to meet up and not leave any gaps right? I think part of the problem is when you extrude the triangles you get a uniform result. Why not make two triangles (interior and exterior faces of wall) and LOFT between them?
I played around with the concept a bit and one piece of additional advice I have to offer is that using 3Dpolylines for some of the triangles might be helpful.
