extruded item apperance
TheNewGuy
Is there a way to change the amount of lines that a made when I extrude a circle? I get 4 lines traveling from circle to circle. Same appearance when I revolve a rectangle. I want something that looks like when I revsurf a rectangle, but without the lines traveling to the center of the circle. I want it to look like a drilled hole from the top view but look like a circle with a thickness from the side.( I can't use a circle with thickness because I need to subtract the item from a polyline shape. )
revolve test.dwg
Isolines? From AutoCAD Help files:
"Specifies the number of contour lines per surface on objects."
The default for this variable is set at 4. Increase it. The max setting is 2047.
