Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Full Member
    TheNewGuy's Computer Details
    XP
    AutoCAD 2009
    Mar 2009
    Cincinnati,Ohio
    94
    Default help with apperance of part
    I was wondering if there is a way to hatch, or something, the angles in this part. Something that would help to make it a little easier to understand. You may have to turn on Shading to see how complex it is. I know I could just turn on shading, but then I loose detail from other perspectives. I cant attach the whole drawing but I have been copying and pasting then 3drotate to get 3 different perspectives all saved on one final drawing. hope this makes sense. Any help would be much appreciated. (I couldn't shrink the file size enough to attach the any dwg) Sooo... hope this is good enough. Thanks again.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,023
    Wild guess. Maybe using a 3DFace would work?
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,023
    TheNewGuy: How about an update. Any luck yet?
    Full Member
    Inventor 2011
    Dec 2008
    South Africa
    54
    Would imprint be what you're after?
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,023
    Quote Originally Posted by czc View Post
    Good suggestion czc. Wish I had thought of that one myself.
  6. #6
    Full Member
    XP
    AutoCAD 2009
    Mar 2009
    Cincinnati,Ohio
    94
    Sorry for the delay I wanted to try and solve the problem first but just ended up re-doing the whole drawing so that each section was in a different color, and this helped a lot, also I was able to then easily designate an exploded view for that section and put it off to the side. I would love to show it to you but I can't fit it, Ziped it is still 1.5mb. Any advice on shrinking these files to fit? Next I am going to piece together a 3D model from all these parts and animate it. So keep an eye out for the questions I am sure to ask about animation, and I will likely need to post a pic, but if this one part is to large than the whole model will surely be to big!
    P.S thanks for your help, I will explore what "imprint" does and see if it could have helped.
    Thanks for all your help.
  7. #7
    Full Member
    Inventor 2011
    Dec 2008
    South Africa
    54
    Well I noticed from your last file that you had three models in one drawing? You could make a new version and remove the extra views leavng only one 3d model and then try purge.
    BTW: Also I played around with the imprint command and you can colour the edges as well.
  8. #8
    Full Member
    XP
    AutoCAD 2009
    Mar 2009
    Cincinnati,Ohio
    94
    OK Thanks I will try the purge command tomorrow. I all ready tried reducing the number of models down to just one and it was still to big to post as a DWG. So I just left it as it was and posted a PDF. BUt I am hopeing this "PURGE" Command will do the trick! I will let you know.
    Thanks for your help
  9. #9
    Full Member
    XP
    AutoCAD 2009
    Mar 2009
    Cincinnati,Ohio
    94
    Default a few more questions...
    Sorry about this thread getting off topic, but I have few more questions.
    1) The "PURGE" Command does not seem to help with shrinking the file size. Not sure why. Any Help with that...
    2) I am exploring using a photo real rendering to post my results and I keep loosing all my text.(see attached)
    3) Can someone who has done it tell me how they were able to post a completely rendered animation in the 250kb restricted file size.
  10. #10
    Full Member
    Inventor 2011
    Dec 2008
    South Africa
    54
    Quote Originally Posted by TheNewGuy View Post
    1) As I understand it. Purge gets rid of items that aren't being used anymore. I guess You don't have any of that yet.
    2) Lines don't get rendered. Text is basically linework. I think you would need to extrude the text somehow. Never tried it though.
    3) I supose you would render the image as normal and then get into an image editting program and shrink the image, that usually brings the size down.
    Hope I have everything correct.
  1. Help me put holes in this part
    By ChrisWatkins in forum AutoCAD 3D Modelling & Rendering
    Last Post: 5th Mar 2012, 04:00 pm
  2. extruded item apperance
    By TheNewGuy in forum AutoCAD 3D Modelling & Rendering
    Last Post: 25th Mar 2009, 02:12 pm
  3. I need help for adaptive part
    By Benoit in forum Autodesk Inventor
    Last Post: 21st Oct 2008, 03:47 pm
  4. Extrude Part to Another Part??
    By RDFB101 in forum Autodesk Inventor
    Last Post: 24th Sep 2008, 09:58 pm
  5. Which layer is this part on?
    By Henri83 in forum AutoCAD Beginners' Area
    Last Post: 1st Apr 2007, 04:15 pm
