I may be way off the mark here, but have you tried the LISP with all your OSNAPs off?
from quickly glancing at the LISP on the hyperlinked threads, I notice that it doesn't turn OSNAPs off before moving the entities...![]()
I've been using the lisp from THIS thread since i got it.
Up untill now have not had any problems, howevey when
i used it today, looking at everythin from the side, it has l
eft entities on 3 distinct elevations,
Any clue's on why this is happening now?
F.Y.I. this is a BIG drawing
Only two things are infinite, the universe and human stupidity, and I'm not sure about the former. - Albert Einstein
SET FILEDIA = 1
Lee Mac Programming
Just another Swamper
Also, check that the entities are not on locked layers, as this will also cause a problem.
Lee Mac Programming
This should cope with R14, and also with objects on locked layers:
Code:(defun c:flat (/ ss ssObj i j) (vl-load-com) (if (setq ss (ssget "X" (list (if (getvar "CTAB") (cons 410 (getvar "CTAB")) (cons 67 (- 1 (getvar "TILEMODE"))))))) (progn (setq ssObj (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex ss))) i 0 j 0) (foreach Obj ssObj (foreach n '(1e99 -1e99) (if (vl-catch-all-error-p (vl-catch-all-apply '(lambda (x) (vla-move x (vlax-3d-point (list 0 0 0)) (vlax-3d-point (list 0 0 n)))) (list Obj))) (setq i (1+ i)) (setq j (1+ j))))) (princ (strcat "\n" (rtos (/ j 2.0)) " Objects Flattened" (if (zerop i) "." (strcat ", " (rtos (/ i 2.0)) " were on a Locked Layer!"))))) (princ "\n<!> No Objects Found <!>")) (princ))
Lee Mac Programming
Thanks 4 the tips - i'll try them tomorraz when I get to work
SET FILEDIA = 1
Good stuff, let me know how you get on![]()
Lee Mac Programming
Will do - won't be untill afternoon tho - am at limb centre in mornin gettin me new leg (Hopefully)
SET FILEDIA = 1
Lee Mac Programming
Only once a year! LOL![]()
SET FILEDIA = 1
Alternatively, this will unlock all layers before performing the flatten:
Code:(defun c:flat (/ laylst ss ssObj j) (vl-load-com) (vlax-for lay (vla-get-layers (vla-get-ActiveDocument (vlax-get-acad-object))) (setq laylst (cons lay laylst))) (mapcar '(lambda (l) (vla-put-lock l :vlax-false)) laylst) (if (setq ss (ssget "X" (list (if (getvar "CTAB") (cons 410 (getvar "CTAB")) (cons 67 (- 1 (getvar "TILEMODE"))))))) (progn (setq ssObj (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex ss))) j 0) (foreach Obj ssObj (foreach n '(1e99 -1e99) (if (vl-catch-all-error-p (vl-catch-all-apply '(lambda (x) (vla-move x (vlax-3d-point (list 0 0 0)) (vlax-3d-point (list 0 0 n)))) (list Obj))) nil (setq j (1+ j))))) (princ (strcat "\n" (rtos (/ j 2.0)) " Objects Flattened."))) (princ "\n<!> No Objects Found <!>")) (princ))
Lee Mac Programming
