Try this for starters:
Code:(defun c:duct (/ *error* oVars vLst dPt dOd Segs dAng vEnt i PntEve PntOdd cAngE sPtE ePtE cAngO sPtO ePtO last_pt1 last_pt2) (defun *error* (msg) (if oVars (mapcar 'setvar vLst oVars)) (princ (strcat "\nError: " (strcase msg))) (princ)) (setq vLst '("CMDECHO" "OSMODE") oVars (mapcar 'getvar vLst)) (if (and (setq dPt (getpoint "\nSelect Point for Elbow: ")) (not (initget 7)) (setq dOd (getdist "\nSpecify Duct OD: ")) (not (initget 7)) (setq Segs (getint "\nSpecify No. of Segments: ")) (setq dAng (getreal "\nSpecify Elbow Angle: ")) (< 0 dAng 360)) (progn (mapcar 'setvar vlst '(0 0)) (command "_arc" "_C" (polar dPt (/ pi 2) dOd) dPt "_A" (rtos dAng)) (setq vEnt (vlax-ename->vla-object (entlast)) i 0.0 inc (/ (vla-get-ArcLength vEnt) Segs)) (while (or (setq PntEve (vlax-curve-GetPointatDist vEnt i) PntOdd (vlax-curve-GetPointatDist vEnt (setq i (+ inc i))))) (setq cAngE (+ (/ pi 2) (angle '(0 0 0) (vlax-curve-getFirstDeriv vEnt (vlax-curve-GetParamAtPoint vEnt PntEve))))) (command "_line" (setq sPtE (polar PntEve cAngE 4.0)) (setq ePtE (polar PntEve (+ pi cAngE) 4.0)) "") (if (and last_pt1 last_pt2) (progn (command "_line" last_pt1 sPtE "") (command "_line" last_pt2 ePtE ""))) (setq cAngO (+ (/ pi 2) (angle '(0 0 0) (vlax-curve-getFirstDeriv vEnt (vlax-curve-GetParamAtPoint vEnt PntOdd))))) (command "_line" (setq sPtO (polar PntOdd cAngO 3.0)) (setq ePtO (polar PntOdd (+ pi cAngO) 3.0)) "") (command "_line" sPtE sPtO "") (command "_line" ePtE ePtO "") (setq last_pt1 sPtO last_pt2 ePtO) (setq i (+ inc i))) (vla-put-Color vEnt acblue)) (princ "\n<!> Points Specified Incorrectly <!>")) (mapcar 'setvar vLst oVars) (princ))
